Clutch switch
Posted: Wed Dec 19, 2012 4:59 pm
by pablotommo
Cruise control stopped working so likely issue is clutch switch I believe. Looks a DIY fix, one question is when you put the new switch in should the clutch be pressed in? Plus any other tips?
Cheers all!
Re: Clutch switch
Posted: Wed Dec 19, 2012 5:44 pm
by adsgreen
pablotommo wrote:Cruise control stopped working so likely issue is clutch switch I believe. Looks a DIY fix, one question is when you put the new switch in should the clutch be pressed in? Plus any other tips?
Cheers all!
No. just quarter turn, take out old switch, swap over and reverse to fit.
Re: Clutch switch
Posted: Wed Dec 19, 2012 6:22 pm
by pablotommo
Cool, presumably clutch switch above clutch and brake switch above brake?
Re: Clutch switch
Posted: Wed Dec 19, 2012 11:46 pm
by F@tBoyF@t
http://forum.rs246.com/viewtopic.php?f= ... CH#p544837
SEE ROY'S step-by-step process to change the clutch switch - really should be a sticky?
Re: Clutch switch
Posted: Thu Dec 20, 2012 12:16 am
by adsgreen
pablotommo wrote:Cool, presumably clutch switch above clutch and brake switch above brake?
Must... Resist... Sarcastic... Answer....
Re: Clutch switch
Posted: Thu Dec 20, 2012 12:19 am
by pablotommo
Cool thanks for the link!!! :0)
Re: Clutch switch
Posted: Thu Dec 20, 2012 7:46 am
by F@tBoyF@t
adsgreen wrote:pablotommo wrote:Cool, presumably clutch switch above clutch and brake switch above brake?
Cool.....
