Page 1 of 2
ESP Light
Posted: Thu Dec 13, 2012 8:24 pm
by nij
My ESP light has come on permanently since last night, does anyone know what it might be?
I haven't had anything done to the car and I haven't had time to do a scan yet. Any ideas?
ESP Light
Posted: Thu Dec 13, 2012 9:03 pm
by Stoo.
Could be a faulty ABS wheel speed sensor, sensor ring, ESP sensors, steering angle sensor, control unit...
Lots of possibles.
Colour is it?
Re: ESP Light
Posted: Thu Dec 13, 2012 9:39 pm
by nij
It's lit up amber.
I'll try to do a scan tomorrow to see if it has thrown any fault codes.
Re: ESP Light
Posted: Thu Dec 13, 2012 10:03 pm
by Stoo.
If the light is on, it will have a code...
Re: ESP Light
Posted: Thu Dec 13, 2012 10:17 pm
by adsgreen
maf sensor too weirdly enough.
Re: ESP Light
Posted: Thu Dec 13, 2012 11:07 pm
by EddyPee
Mine came on and stayed on some time back, driving and braking felt normal, turned out to be stuck brake light sensor, check if your lights are stuck on, if so could be same, cheap fix, sub £100 I think
Re: ESP Light
Posted: Fri Dec 14, 2012 1:07 am
by usedcar
maf gives load info for the esp. so if not working correct will cause esp, but should also be possibly causing a check engine light.
Re: ESP Light
Posted: Sat Dec 15, 2012 4:14 pm
by nij
adsgreen wrote:maf sensor too weirdly enough.
It looks like the MAF Sensor have something to do with it, here's the scan. Two faults found.
Address 01: Engine Labels: 079-910-560-BNS1.lbl
Part No SW: 8E1 910 560 HW: 8E1 907 560
Component: 4.2L V8/4V FSI ª0090
Revision: 57H15--- Serial number: XXXXXXXXXXXXXX
Coding: 01040003180F0160
Shop #: WSC 00191 264 15243
VCID: E3CE58C022683300DC7
1 Fault Found:
000257 - Mass Air Flow Sensor (G70)
P0101 - 008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 2
Mileage: 51715 km
Time Indication: 0
Freeze Frame:
RPM: 1592 /min
Load: 27.4 %
Speed: 12.0 km/h
Temperature: 75.0°C
Temperature: 42.0°C
Absolute Pres.: 980.0 mbar
Voltage: 13.335 V
Readiness: 0000 1000
Address 03: ABS Brakes Labels: 8E0-910-517.lbl
Part No SW: 8E0 910 517 G HW: 8E0 614 517 BD
Component: ESP8 quattro H06 0150
Revision: 00000000 Serial number: 00000000000000
Coding: 0004533
Shop #: WSC 06335 000 00000
VCID: 2B5E70E08A383B40A47
1 Fault Found:
18265 - Load Signal
P1857 - 000 - Error Message from ECU
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 17
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x4500
Hex Value: 0x4006
Hex Value: 0x0028
Hex Value: 0x01A7
Hex Value: 0x0001
I've cleared the fault codes and the ESP light is now off, but I haven't had a chance to drive the car yet.
Is the MAF Sensor on its way out and need replacing?
Re: ESP Light
Posted: Sat Dec 15, 2012 5:51 pm
by RIV
Replaced my air mass sensor a while back now, it made the car feel much more responsive, has your car done many miles?
ESP Light
Posted: Sat Dec 15, 2012 5:57 pm
by The_Coat
Silas wrote:Replaced my air mass sensor a while back now, it made the car feel much more responsive, has your car done many miles?
Are they easy to replace?
Re: ESP Light
Posted: Sat Dec 15, 2012 6:17 pm
by RIV
My mechanic replaced mine, but i think they are supposed to be easy to fit, im sure somone will step in and give some more detailed advise on replacing
ESP Light
Posted: Sat Dec 15, 2012 6:20 pm
by The_Coat
I had the ESP and traction light come on mine a month or so ago but turning the car off and on again it's been fine since.
I was driving in really heavy rain on the M25 for about an or so not sure if water got where it shouldn't have.
Was advised on here it could be the MAF
Re: ESP Light
Posted: Sat Dec 15, 2012 8:42 pm
by adsgreen
Anybody who needs help replacing the maf bees to hand in their man cards
Re: ESP Light
Posted: Sat Dec 15, 2012 9:23 pm
by RIV
I can afford to pay for my car to be fixed
Re: ESP Light
Posted: Sat Dec 15, 2012 9:33 pm
by nij
Had a quick run with my car and everything seems fine, with no warning ESP light.
Prior to the ESP light coming on, I did notice the engine wasn't running as smooth as normal and the gear change was a bit snappy. My car has done 32k miles and I think replacing the MAF Sensor is straight forward. Now I just wanted to know if it's worth replacing and how much is it for a new MAF Sensor.
