KW V3 Setup
KW V3 Setup
I will be replacing DRC with KW V3s next week. Car already has front and rear Hotchkis sways. Can anyone point me to threads talking about known good setups? I would like to get a good baseline quickly and then make adjustments to my preferences. Thanks!
Re: KW V3 Setup
Maybe this thread can be helpful for you.
viewtopic.php?f=35&t=115808&p=743193&hi ... up#p743193
Mugello RS4 avant-08
Re: KW V3 Setup
The standard setting out the box are pretty good & set up for the car.
Ride height can be fairly easily adjusted afterwards if needed. They will settle a bit after first install so probably best to install a little bit high.
Re: KW V3 Setup
Whatever you pick please remember this. Crunched my front splitter off of a footpath while parking many years ago just a week or so after having fitted Bilsteins and the front had sunk/settled down. Can still hear the noise
Re: KW V3 Setup
Thanks all! Appreciate the help.
