Aircon not working
Frazz82
Aircon not working
Post by Frazz82 » Sat Aug 17, 2024 11:37 pm
The aircon doesn't work it holds the gas and the fuses are ok so while I had the front end off I took a punt an changed the aircon pressure switch but it didn't work.
So before I look at the aircon pump is there anything else it could be ?.
m5killer
Re: Aircon not working
Post by m5killer » Sun Sep 01, 2024 1:24 pm
Receiver drier I have the same problem as well as a leaking pipe that goes to the above
Kanerrad
Post by Kanerrad » Tue Dec 17, 2024 9:28 pm
I had a similar issue a couple of months ago and it was found to be the main fan motor that was the issue. Once replaced, everything worked as it should
Users browsing this forum: Google [Bot] and 29 guests
