Anyone need replacement intake flap actuator linkage parts?
Wavey Dynamicist
I suspect mine has failed or is on it's way so i'm gonna design up some replacement collar & linkage parts to be machined from aluminium. The problem seems to be that the stock plastic parts wear with time and some play develops in the system which the actuator doesn't like.
To be clear it'll be both the linkage arm and the collar which fits over the shaft (if i can figure out how to remove the stock part!)
Would anyone else be in the market for this if i make it available?
2007 RS4 Saloon; Mugello Blue
Re: Anyone need replacement intake flap actuator linkage parts?
Yes, I still run with my inlet flaps so yes, if you start making up longer lasting sets I would be interested.
Misano Red RS4 B7 Avant
I’m a new owner but I had a similar thing on my R32. So I’d be interested too.
Is this the same part that 034 motorsport sell?
Wavey Dynamicist
1/2 of the kit would be yeah.. The issue with theirs is that it still has to match the stock plastic collar on the shaft, if the collar is worn and you only put a new linkage on, you'll still get play in the system which defeats the object. You also then have the added problem that the new metal linkage would then accelerate the wear on the collar.
What I'm doing is developing both matching parts to create a more robust fix - just got to do a little more investigation into how to remove the stock plastic collar from the flap shaft and it'll be good to go.
I'll keep you guys up to date. Thanks for feedback.
Late response, but as a recent new RS owner I’d be interested if you do fabricate them. Have you progressed the development of these?
I would also be interested in these. My RS4 has been sitting in the garage since a month trying to find a good quality replacement...
beckford21
Wavey Dynamicist
Well, i appreciate you guys digging this one up. The arms are actually complete and sitting on our computer. my EPC light hasn't returned and other projects came in and they got parked, but the next step would be to get them fabricated and verify they're the correct fitment to get them signed off for production.
If anyone wants to try them out and help me sign off the dimensions, i'd be happy to give you a development set for the cost of fabrication.
Reach out if you're interested and we can get it rolling.
Can I buy intake flap actuator linkage parts?
Wavey Dynamicist
How did this go? Still operating smoothly?
Yes, very well. The replaced part is stronger than the original.
Users browsing this forum: No registered users and 40 guests
