The aircon doesn't work it holds the gas and the fuses are ok so while I had the front end off I took a punt an changed the aircon pressure switch but it didn't work.
So before I look at the aircon pump is there anything else it could be ?.
Aircon not working
Re: Aircon not working
Receiver drier I have the same problem as well as a leaking pipe that goes to the above
I had a similar issue a couple of months ago and it was found to be the main fan motor that was the issue. Once replaced, everything worked as it should
Users browsing this forum: Bing [Bot], Google Adsense [Bot] and 41 guests
