Jerking whilst accelerating in 3rd gear
johnhalton
Post by johnhalton » Sun Jun 18, 2023 7:56 pm
Hi!
Brand new on here and some really interesting threads that have helped me already but wanted to get thoughts on the problem I’m having.
In short, the car runs great 99% of the time - recently had carbon clean, new injectors, new MAF sensor, new spark plugs, throttle body cleaned.. as maintenance I planned to do after buying the car about 2 months ago.
However, it’s jerking occasionally under semi-hard acceleration in 3rd gear (only noticed in 3rd gear anyway) - and it’s annoying.
Seems very variable when it does it, has done it when cold and after being driven for a while - and I can’t always recreate it even directly after it’s just done it.
No fault codes showing when the dealer have tested it and driven it with live data (all be it they’ve not been able to replicate it)
Any thoughts? Best guess so far from other comments is maybe a coil pack on its way out.
Thanks in advance!
SeikoKid
Re: Jerking whilst accelerating in 3rd gear
Post by SeikoKid » Mon Jun 19, 2023 11:57 pm
mine does it in first / 2nd when and i feel like i’m learning to drive again. It’s pretty violent and i have to press the clutch to stop it
It’s all down to your driving - your not applying enough power so it is telling you your an idiot
Easthill
Post by Easthill » Sun Aug 20, 2023 7:48 am
ever change the snub mount?
Joel_RS4
Post by Joel_RS4 » Tue Aug 22, 2023 6:28 pm
Lol mine does this too in 1st or 2nd at random. Probably happens once every other drive. I'm curious if anyone ever figured out a fix.
JamesBaby
Post by JamesBaby » Thu Aug 24, 2023 9:39 am
It sounds to me you may have an intermittent vacuum leak causing a momentary lean condition causing that car to knock. I violent cutting out can be a symptom. Maybe after all that work a vac line wasn't properly installed. Check the various solenoids and vac lines such as the flap in the air box, and the one on the front of the engine. Let's hope it's not the one under the inlet.
Users browsing this forum: No registered users and 118 guests
