Hi all,
I'm looking for some insight and advice as my 2007 RS4 B7 is very hard to get into R, 1, & 2, and often grinds slightly changing into higher gears. This is an intermittent problem becoming more frequent over time, but when it works it's perfect. It will also move forward in 1st with my foot on the clutch and off the brake (like an auto does in D with your foot off the brake), making me think that the clutch isn't properly disengaging, which might also explain why its difficult to get into and change gear? I cannot make the clutch slip at all no matter how much I ride it.
I have been told by an Audi mechanic that the clutch is completely screwed and needs replacing (yet I can drive it normally, mostly), but a clutch specialist said its engaging and disengaging fine, so he didn't think the clutch is the problem.
I have no issue replacing the clutch if it is the issue, but I don't want to spend AU$7,000 on it just to find it is something else. The symptoms read like they are similar to a failing slave or even master cylinder, I just don't know how to tell, is it worth replacing these to see if it fixes the problem? I also understand that with the self-adjusting clutch, there is no way to manually adjust its engagement, does this mean it is just worn out and therefore can't self-adjust enough to disengage properly?
Any help is much appreciated.
Andy
B7 RS4 Clutch Problem?
Jump to
- General Discussion Forums
- ↳ Welcome Area
- ↳ General Car Chat
- ↳ Trackdays and Meets
- ↳ Spotters Forum
- ↳ Adversaries
- ↳ BMW M & Alpina
- ↳ Jaguar R
- ↳ Mercedes-AMG
- ↳ Nissan GT-R
- ↳ Opel VXR & HSV
- ↳ McLaren
- ↳ Porsche
- ↳ Volvo S60 Polestar
- ↳ Other
- ↳ Audi S and RS Ownership
- ↳ DTC / VCDS
- ↳ Electrical
- ↳ Cleaning & Car Care
- ↳ Readers' Rides
- ↳ Off Topic Chat
- ↳ Cars
- ↳ Parts
- ↳ Group Buys
- ↳ Other
- ↳ Ads Up To End Of 2010
- ↳ RS2 (B4) 1994-1995
- ↳ RS3 (8PA) 2011-2012
- ↳ RS3 (8VA) 2015-
- ↳ TTRS (Mk3 Typ 8S) 2014–
- ↳ RS4 (B5 Typ 8D) 1999-2001
- ↳ RS4 (B7 Typ 8E) 2006–2008
- ↳ RS4 (B8 Typ 8K) 2012-2016
- ↳ RS4 (B9 Typ 8W) 2017-
- ↳ RS5 (8T) 2010–2015
- ↳ RS5 (F5) 2016–
- ↳ RS6 (C7 Typ 4G) 2013-2018
- ↳ RS6 (C8 Typ 5G) 2019-
- ↳ RS7 (4G) 2013-2019
- ↳ RS7 (C8) 2019-
- ↳ RS Q3 (Typ 8U) 2013-
- ↳ RS e-tron GT (J1) 2020-
- Audi S Discussion Forums
- ↳ S Forums (Up to 1997)
- ↳ S1
- ↳ S2
- ↳ S4 2.2 / S4 4.2
- ↳ S6 / S6 Plus
- ↳ S1 (Typ 8X) 2014-
- ↳ S3 (Typ 8L) 1999-2003
- ↳ S3 (Typ 8P) 2006-2012
- ↳ S3 (Typ 8V) 2013-
- ↳ TTS (Typ 8J) 2008-2014
- ↳ TTS (Typ 8S) 2014-
- ↳ S4 (B5 Typ 8D) 1997-2002
- ↳ S4 (B8 Typ 8K) 2009-2016
- ↳ S4 (B9 Typ 9L) 2017-
- ↳ S5 (B9) 2017-
- ↳ S6 (C5 Typ 4B) 1999-2003
- ↳ S6 (C6 Typ 4F) 2006-2011
- ↳ S6 (C7 Typ 4G) 2012-2018
- ↳ S6 (C8) 2019-
- ↳ S7 (Typ 4G) 2012-2017
- ↳ S8 (D2 Typ 4D) 1992-2002
- ↳ S8 (D3 Typ 4E) 2002-2009
- ↳ S8 (D4 Typ 4H) 2010-
- ↳ SQ2 (MQB) 2019-
- ↳ SQ5 (Typ 8R) 2013-2017
- ↳ SQ5 (Typ FY) 2017-
- ↳ SQ7 (Typ 4M) 2016-
- ↳ SQ8 (MLB) 2019-
- ↳ Circuit Days
- ↳ Destination Nurburgring
- ↳ EM Tuning Products
Users browsing this forum: Majestic-12 [Bot] and 84 guests
