Forge Oil Cooler fitted
DocMcc
Re: Forge Oil Cooler fitted
Post by DocMcc » Tue Oct 26, 2021 8:59 pm
12th, Did your garage manage to fabricate replacement pipes?
12th
Post by 12th » Wed Oct 27, 2021 8:29 am
No, too corroded at pipe and cooler ends.
flylife2k
Post by flylife2k » Thu Nov 18, 2021 12:06 pm
12th wrote:
Sun Oct 10, 2021 9:20 am
Thanks. Car gets returned tomorrow - can't drive it for a week or two because of surgery on Friday. Tsk...
Hope surgery went well bud
12th
Post by 12th » Thu Nov 18, 2021 12:12 pm
Yep, back to firing on all cylinders, thanks.
Oliver89
Post by Oliver89 » Sun Jan 16, 2022 12:03 am
I would be interested to know what combination causes the issue. Because you can buy Audi replacement lines from LLL Parts and then get a radtec for around £700. But if the original lines will corrode with the radtec cooler it doesn’t make sense. Again, I’m assuming JHM lines also resolve the issue and could be used with radtec cooler. Although it appears they may lack quality control as per the above post. MDM technick is the cheapest Forge I could find at £924.78
