Exhaust and noise questions...
Neuromancer
Post by Neuromancer » Fri Jul 02, 2021 7:59 pm
Hi all,
I'm after some of your expert advice with a few questions if you'd be so kind. I've tried google/forum searches but seem to read conflicting opinions.
I have a non-resonated Milltek, and presume the pre-cats have not been gutted, the ECU is currently standard Audi map but intake flaps have been removed.
The issue is I'm quite self-conscious how noisy the car is in my little village, primarily on cold start rather than pootling.
I'm looking at options and need your help:
1. Arrange for a tune to delete the cold-start shenanigans (either a stand alone thing or part of a stage 2). For this should I gut the pre-cats to avoid "issues", and if I do need to will the car be noticeably louder at other times.
2. Look to replace the non-resonated section with a resonated. Worth asking in the classifieds for a swap (obvs with money their way)?
Caveats:
I'm just about ok with the drone with the non-resonated and have heard that no precats can raise the rev's a bit that this occurs which would help when just cruising.
I'm not too bothered about power gains and appreciate probably gutting/removing pre-cats with a stage 2 tune including cold start delete is I imagine the best idea...but I'm conscious of cost/insurance etc which I'm probably ok with but not if drone and general loudness worsened - hence the question!
Over to you..... :beerchug:
Silverfox42
Re: Exhaust and noise questions...
Post by Silverfox42 » Fri Jul 02, 2021 9:10 pm
Just a thought, return to a stock exhaust (Plenty about) and sell the Milly?
Previous:
Neuromancer
Post by Neuromancer » Fri Jul 02, 2021 11:28 pm
Thank you. Not a bad option, will ponder. Anyone else with opinions?
coffey555
Post by coffey555 » Sun Jul 04, 2021 12:14 am
As above, return to stock. You can always remove the centre res section on the OEM exhaust if you feel it is too quiet.
Virtually no drone but a very nice noise. If you keep the valves working it will not be too loud on cold startup (mine are permanently open and it's a bit much first thing in the morning!).
Misano Red RS4 B7 Avant
d7ve_b
Post by d7ve_b » Sun Jul 04, 2021 7:06 am
I’ve just gone back to stock but swapped the centre box for an x-pipe, spot on for me!
Silverfox42
Post by Silverfox42 » Sun Jul 04, 2021 5:28 pm
d7ve_b - can you advise where you got the X-Pipe and if there are any issues come MOT time?
Previous:
d7ve_b
Post by d7ve_b » Sun Jul 04, 2021 6:44 pm
X-pipe was fabricated and fitted by CM Tuning, shouldn’t be any MOT issues as the centre box doesn’t filter anything, it just quietens it down.
Silverfox42
Post by Silverfox42 » Sun Jul 04, 2021 7:14 pm
Awesome, thank you
Previous:
Neuromancer
Post by Neuromancer » Sun Jul 04, 2021 8:10 pm
Thanks all. Will ponder... interesting on the revert back to OEM as although many moons ago I had been in friends RS4's I have never actually driven one with an Audi exhaust. The H or X pipe mod does seem a worthwhile option..
Neuromancer
Post by Neuromancer » Mon Jul 19, 2021 9:26 pm
Just to close this to a conclusion, I've gone for the Milltek resonated centre section as logistics of collecting/fitting a used OEM exhaust was proving tricky.
So far, much improved in all areas - start-up drama and drone both back into "civilised" territory, without being boring. 8)
ethanpratt
Post by ethanpratt » Sun Jul 25, 2021 6:07 pm
I have the same issue and yes, google doesn't help. in fact, it confuses me more. Im just glad that I was able to find this thread. i took some of the advice and my problem has just been resolved. thanks!
Users browsing this forum: No registered users and 194 guests
