hi all
My UK 57-plate B7 RS4 Avant with 92k miles has developed what feels like a slight judder, and I figured it might be transmission related. It's most notable when the car is cold, and when at low revs but above idle (2-3k), on steady throttle or when engine braking, and it just gives a grumbling judder like you're driving over rippled road surface. Sitting on cruise control at 40mph sometimes feels like the transmission is slipping ever so slightly - it feels like the revs are see-sawing ever so slightly but not enough to notice on the rev counter - just not steady and smooth.
I had a CV joint replaced late last year and noticed the tranny chatter after that, though it's quite possible that it had been present before; the garage who did that work said it might be a gearbox issue (car is on the original clutch AFAIK) and recommended a transmission specialist, who took a look at the car and pulled some DTCs (which to my shame I didn't think of doing before taking it to them). So I ran it through VCDS myself when I got it home - amongst the various codes caused by (I think) a flat battery some weeks ago, were 60 instances of:
005491 - Left Engine Mount Solenoid Valve (N144): Open Circuit
P1573 - 004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 60
Mileage: 141140 km <-- ie about 4,000 miles ago
Now if the active engine mounts reduce vibration, particularly when pressing on, would a duff mount - or an electrical problem to the solenoid valve - cause a fairly noticeable juddering at low and steady speeds?
The Right Engine Mount Solenoid Valve is also showing one instance of the same fault, but it's as of current mileage - so I wonder if it's a phantom...
Maybe I'll just get the car booked in to have both mounts replaced anyway - I'm supposing the labour to do both won't be 2x the labour to do one...
cheers
Ewan
Engine mount solenoid failure - causing a feeling like grumbly transmission?
Jump to
- General Discussion Forums
- ↳ Welcome Area
- ↳ General Car Chat
- ↳ Trackdays and Meets
- ↳ Spotters Forum
- ↳ Adversaries
- ↳ BMW M & Alpina
- ↳ Jaguar R
- ↳ Mercedes-AMG
- ↳ Nissan GT-R
- ↳ Opel VXR & HSV
- ↳ McLaren
- ↳ Porsche
- ↳ Volvo S60 Polestar
- ↳ Other
- ↳ Audi S and RS Ownership
- ↳ DTC / VCDS
- ↳ Electrical
- ↳ Cleaning & Car Care
- ↳ Readers' Rides
- ↳ Off Topic Chat
- ↳ Cars
- ↳ Parts
- ↳ Group Buys
- ↳ Other
- ↳ Ads Up To End Of 2010
- Site Sponsors
- ↳ MRC Tuning
- ↳ RS2 (B4) 1994-1995
- ↳ RS3 (8PA) 2011-2012
- ↳ RS3 (8VA) 2015-
- ↳ TTRS (Mk3 Typ 8S) 2014–
- ↳ RS4 (B5 Typ 8D) 1999-2001
- ↳ RS4 (B7 Typ 8E) 2006–2008
- ↳ RS4 (B8 Typ 8K) 2012-2016
- ↳ RS4 (B9 Typ 8W) 2017-
- ↳ RS5 (8T) 2010–2015
- ↳ RS5 (F5) 2016–
- ↳ RS6 (C7 Typ 4G) 2013-2018
- ↳ RS6 (C8 Typ 5G) 2019-
- ↳ RS7 (4G) 2013-2019
- ↳ RS7 (C8) 2019-
- ↳ RS Q3 (Typ 8U) 2013-
- Audi S Discussion Forums
- ↳ S Forums (Up to 1997)
- ↳ S1
- ↳ S2
- ↳ S4 2.2 / S4 4.2
- ↳ S6 / S6 Plus
- ↳ S1 (Typ 8X) 2014-
- ↳ S3 (Typ 8L) 1999-2003
- ↳ S3 (Typ 8P) 2006-2012
- ↳ S3 (Typ 8V) 2013-
- ↳ TTS (Typ 8J) 2008-2014
- ↳ TTS (Typ 8S) 2014-
- ↳ S4 (B5 Typ 8D) 1997-2002
- ↳ S4 (B8 Typ 8K) 2009-2016
- ↳ S4 (B9 Typ 9L) 2017-
- ↳ S5 (B9) 2017-
- ↳ S6 (C5 Typ 4B) 1999-2003
- ↳ S6 (C6 Typ 4F) 2006-2011
- ↳ S6 (C7 Typ 4G) 2012-2018
- ↳ S6 (C8) 2019-
- ↳ S7 (Typ 4G) 2012-2017
- ↳ S8 (D2 Typ 4D) 1992-2002
- ↳ S8 (D3 Typ 4E) 2002-2009
- ↳ S8 (D4 Typ 4H) 2010-
- ↳ SQ2 (MQB) 2019-
- ↳ SQ5 (Typ 8R) 2013-2017
- ↳ SQ5 (Typ FY) 2017-
- ↳ SQ7 (Typ 4M) 2016-
- ↳ SQ8 (MLB) 2019-
- ↳ Circuit Days
- ↳ Destination Nurburgring
- ↳ EM Tuning Products
Users browsing this forum: Google [Bot] and 40 guests
