Front parking sensors
bazza138
Post by bazza138 » Sun Feb 28, 2021 5:31 pm
afternoon all .
I after bit of help and advice!
After a wiring diagram or a solution .
So far ,
Parking sensors not working, fuse ok 10amp . Rear sensors I can hear clicking from each one , fronts not .
So Front bumper off , changed all sensors.
And Still no joy . Also no dc from any pins from front connect plug .
So not sure if this runs through a relay ??
Any help or ideas
Thanks In Advance Barry
FaisalJ
Re: Front parking sensors
Post by FaisalJ » Sun Feb 28, 2021 8:02 pm
Baz! You’re alive! How’s life with sprog treating you?
I can’t help at all with your issue - sorry...
2007 RS4 B7 Avant
Bill'sRS4
Post by Bill'sRS4 » Mon Mar 01, 2021 2:02 pm
Have you checked the dash switch that turns them on and off?
bazza138
Post by bazza138 » Wed Mar 03, 2021 4:26 pm
FaisalJ wrote:Baz! You’re alive! How’s life with sprog treating you?
Haha yes . I’m hanging in there ! , little monkey just turned 2 !
Hope your all well and safe
bazza138
Post by bazza138 » Wed Mar 03, 2021 4:27 pm
Bill'sRS4 wrote:Have you checked the dash switch that turns them on and off?
Nope not yet Bill , I check that one out over the weekend
Thanks Image
bazza138
Post by bazza138 » Sun Mar 14, 2021 2:52 pm
Only got round to check the switch all is working ok .
Bit stumped may have to book this in for a Indy !
mikep99
Post by mikep99 » Sun Mar 14, 2021 2:55 pm
have you checked the connector you have to disconnect to remove the bumper?
There's 3, one will be for the sensors - probably the biggest of the connectors.
The other 2 will be fog lights and air temp sensor.
Mike
bazza138
Post by bazza138 » Sun Mar 14, 2021 2:59 pm
mikep99 wrote:have you checked the connector you have to disconnect to remove the bumper?
Mike
Yep bumpers is off , lying in front on car Nothing from the plug from main loom . I would of though I get at least 6-12 v dc ?
mikep99
Post by mikep99 » Sun Mar 14, 2021 3:05 pm
sorry, just noticed you put that in your first post.
The bumper's off mine at the mo so I'll check for voltage tomorrow if I remember.
Have you checked the connector into the PDC controller? behind the left hand side boot trim?
mikep99
Post by mikep99 » Sun Mar 14, 2021 3:06 pm
Have you scanned it at all? What does it say?
bazza138
Post by bazza138 » Sun Mar 14, 2021 3:08 pm
mikep99 wrote:sorry, just noticed you put that in your first post.
Thanks for quick reply Mike
Sorry PDC ?
I think I know where u mean . Nope I haven’t checked there on it Now .
mikep99
Post by mikep99 » Sun Mar 14, 2021 3:09 pm
Parking Distance Control = PDC = parking sensors :)
bazza138
Post by bazza138 » Tue Mar 23, 2021 4:10 pm
I’ve just changed the PDC module , still same error !
Stumped now .
Do you think this runs through any relays ?
