Front parking sensors
afternoon all .
I after bit of help and advice!
After a wiring diagram or a solution .
So far ,
Parking sensors not working, fuse ok 10amp . Rear sensors I can hear clicking from each one , fronts not .
So Front bumper off , changed all sensors.
And Still no joy . Also no dc from any pins from front connect plug .
So not sure if this runs through a relay ??
Any help or ideas
Thanks In Advance Barry
So far ,
Any help or ideas
Re: Front parking sensors
Baz! You’re alive! How’s life with sprog treating you?
I can’t help at all with your issue - sorry...
2007 RS4 B7 Avant
Have you checked the dash switch that turns them on and off?
Haha yes . I’m hanging in there ! , little monkey just turned 2 !FaisalJ wrote:Baz! You’re alive! How’s life with sprog treating you?
Hope your all well and safe
Nope not yet Bill , I check that one out over the weekendBill'sRS4 wrote:Have you checked the dash switch that turns them on and off?
Only got round to check the switch all is working ok .Bill'sRS4 wrote:Have you checked the dash switch that turns them on and off?
Bit stumped may have to book this in for a Indy !
have you checked the connector you have to disconnect to remove the bumper?
There's 3, one will be for the sensors - probably the biggest of the connectors.
The other 2 will be fog lights and air temp sensor.
Mike
Mike
Yep bumpers is off , lying in front on car Nothing from the plug from main loom . I would of though I get at least 6-12 v dc ?mikep99 wrote:have you checked the connector you have to disconnect to remove the bumper?
Mike
sorry, just noticed you put that in your first post.
The bumper's off mine at the mo so I'll check for voltage tomorrow if I remember.
Have you checked the connector into the PDC controller? behind the left hand side boot trim?
Have you scanned it at all? What does it say?
Thanks for quick reply Mikemikep99 wrote:sorry, just noticed you put that in your first post.
Sorry PDC ?
I think I know where u mean . Nope I haven’t checked there on it Now .
Parking Distance Control = PDC = parking sensors
I’ve just changed the PDC module , still same error !
Stumped now .
Do you think this runs through any relays ?
Stumped now .
Users browsing this forum: Google [Bot] and 116 guests
