Another few questions... so what would happen if you put the incandescent bulbs in the drls with the ecu resistor mod? Do you think you would fry the ecu? And with the parking lights does changing the resistor work on the uk/European models and for a saloon?
I’ve got another ecu here ready to mod haha
Clean LED DRL Modification (Without Resistors)
Re: Clean LED DRL Modification (Without Resistors)
And you should be able to change the vin number in the coding or adaptation
