backfiring in intake after flap delete
MK06
Post by MK06 » Thu Dec 10, 2020 11:02 am
Hello everyone
So I recently DIY'ed the intake manifold flap delete.
For some reason, the car now backfires like crazy in the intake on every cold start but settles down once it warms up and the revs go down.
The car is bone stock and hasn't been flashed before. I don't have any CEL on the dash.
Has anyone else also experienced this?
Also, can it cause any damage of some sort?
TrevoRS4
Re: backfiring in intake after flap delete
Post by TrevoRS4 » Tue Dec 15, 2020 1:27 am
Mine will sputter a bit as I get past half throttle or so. Only when cold. It’s more significant now with the cold weather versus when I had it deflapped over the summer.
MK06
Post by MK06 » Fri Dec 18, 2020 2:31 pm
@TrevoRS4 Mine backfires (sounds like popcorn popping) continuously in the intake on every cold start. When doing the deflap, do you remove only the flaps on the intake or do you remove the dividers in the port as well?
TrevoRS4
Post by TrevoRS4 » Wed Dec 23, 2020 1:42 pm
Removed both the flaps and dividers
MK06
Post by MK06 » Sun Dec 27, 2020 6:39 am
Thanks bud, mine also has both the flaps and dividers removed so I'm not sure where the problem might be. I'm starting to think that a flash is necessary, has your vehicle been flashed bud?
mojoe
Post by mojoe » Sun Dec 27, 2020 6:46 am
was thinking about removing mine,when I did a carbon clean. Phoned MRC first,they said " your car will go into limp mode,and you will need a £600 remap ".
So I left them in
MK06
Post by MK06 » Mon Dec 28, 2020 8:34 pm
My car runs completely normal, no limp mode or CEL at all. I just removed the flaps and left the shaft in place. The only thing is the dreaded backfiring on every cold start. It doesn't seem like a common problem after the flap delete. I might consider putting the flaps back in to solve the issue.
Grandadg90
Post by Grandadg90 » Tue Dec 29, 2020 2:48 am
Best bet is to deflated the manifold, remove the pre-cats and have the car mapped. Rob from Nicholson motors(Doncaster), who knows his RS's really well will map it for way less than £600. I had mine done, hugh difference.
Daytona Grey, Bilstein Coilovers, Pre-cat delete, Centre resonator delete, IM flaps/vains delete, Interior/Exterior LED kit, CAI, Black Optics.
Other car: Bread Van
MK06
Post by MK06 » Wed Dec 30, 2020 9:55 am
Thank you @Grandadg90, I will consider that.
Users browsing this forum: Google Adsense [Bot] and 188 guests
