H & R 8mm Hubcentric Spacers - Where?
As above, need 2 x Hubcentric 8mm spacers. Can’t seem to find them anywhere apart from on E Bay and the seller isn’t answering my question. Need silver coloured, not black.
Can anyone help?
Can anyone help?
suurenmoinen
Re: H & R 8mm Hubcentric Spacers - Where?
I have the same problem. Have they stopped making them?
2007 RS4 | Phantom Black | Milltek'ed | LED DRL'ed | H&R wheel spaced | 034 Density Line control armed | Hotchkis F + R Sway Barred | K&N Filtered | Ziza lit | Lamix-ed | Passport 9500ix hardwired | Dension Pro BT'ed | StopTech Brake Padded
They aren’t Hubcentric.RS4eddie wrote: ↑Thu Apr 02, 2020 4:03 pmYou guys check Achtuning yet?
https://www.achtuning.com/h-r-1655572-5 ... olkswagen/
Look on E Bay. There’s a seller on there. Picture has a set in silver and black as the main picture. Sent them a message and now ordered a set from them in silver. Good price toosuurenmoinen wrote: ↑Thu Apr 02, 2020 11:39 amI have the same problem. Have they stopped making them?
The ones I ordered from them are. Also read the description...DavidRS4 wrote:They aren’t Hubcentric.RS4eddie wrote: ↑Thu Apr 02, 2020 4:03 pmYou guys check Achtuning yet?
"H&R 1655572 Wheel Spacers are the answer if you need more brake clearance or just want a more aggressive look from your wheels. H&R spacers are hubcentric for a perfect fit and no vibration. H&R DR series spacers fit between the wheel and hub, using longer wheel bolts (sold separately)."
I just looked at the picture.
There's this version too:
H&R B1655571 DR-System Wheel Spacer Set 16mm per axle Pattern 5x112-Hub 57,1mm-Bolt Size M14x1,5-Audi/Seat/Volkswagen/Ford-Black
Anyone know the difference between x571 and x572?
Have you tried EuroCarParts?
Otherwise Virdee on here can supply them.
I would go with a main supplier as above
As you will need longer bolts too
I would be weary getting those from ebay
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
Users browsing this forum: Google Adsense [Bot] and 811 guests
