You won't look back with the koni honestly
DRC failure-specialist recommendations required
Re: DRC failure-specialist recommendations required
B7 saloon, koni Shocks and h and r springs, h and r spacers 8mm f+r, milltek non res with valves, milltek d/ps, k and n filter, full mrc carbon clean, mrc stage 2 with l/c and f/s 456bhp 522nm.
I am after the Koni kit for mine. PM sent.Shockerboy wrote: ↑Sun Mar 22, 2020 4:07 pmThe KONI kit we do has very special valving and is designed to be stiffer in slow shaft speeds IE high speed cornering and harsh braking . it is also Softer in hi speed shaft movements IE bumpy surfaces , This is why the fitting of KONI dampers doesnt need uprated ARB because the shock can limit body roll better than the DRC did .
This valving facilitates improved Handling and comfort and is why Gary is feeling a firmer ride , BUT still comfortable .
Resurrecting an old thread guys, but as not really tech savvy and new to the forum, is there a list of who can repair the DRC ( just had a pipe burst and my specialist in West Yorkshire, doesn't have the set up to fix )
Users browsing this forum: Google Adsense [Bot] and 914 guests
