Does anyone know what they did to the V8 S4 engine to achieve another 80bhp?
I'm assuming you cant squeeze much more than 40bhp from an NA engine by remapping and exhaust.
What are the key differences between S4 and RS4?
Clive
- johneroberts
RE: What are the key differences between S4 and RS4?
The RS4 engine was fiddled with by Cosworth so its their "BlackArt" that give you the difference
jr
jr
Driving is believing
RS246 Founder
From what I recall it's a totally new head. It's now the more efficient FSI engine. There are rumours they'll replace the current S4 4.2 V8 with the FSI one but I personally think it won't fit with the marketing.
B8 A4 Avant quattro
Honda CBR1100XX Super Blackbird
Suzuki GSXR1000 (Track bike)
B6 S4 (AMD Stage 3) - GONE
8N TT (APR/AMD/MTM) - GONE
they should drop the s4 and bring out an rs4 lightweight, the b7 rs4 should become the s4.
then we have a true fight:
s4(b7 rs4) vs m3
rs4(lightweight) vs m3csl
s4(b7 rs4) vs m3
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
Dave, I work in South Leeds.
Clive
Can someone please explain what the FSI engine is all about
Clive
- martinhans
- 1st Gear
Taken from audi's website
FSI: more power from less petrol.
The Mulsanne straight at Le Mans, where the leading competitors reach speeds of over 200mph each lap during 24 hours of non-stop racing, may seem an unlikely proving ground for a new breed of highly economical petrol engines. But, true to Audi's famous 'Vorsprung durch Technik' philosophy, Audi FSI technology played its part in three consecutive Le Mans victories for the all-conquering Audi Infineon R8 racers before making its UK debut in the more familiar surroundings of the public roads.
Le Mans is, of course, hardly an economy run. But for the teams who enter the annual contest of speed and endurance it still pays dividends to have an efficient engine, one that can make the most effective use of every drop of petrol, thus reducing the number of pit stops a car has to make. And the same goal - fuel efficiency - makes FSI technology highly attractive to the company car driver, too.
Today, Audi FSI engines combine good performance, low emissions and excellent economy. The 2-litre, 4-cylinder A4 2.0 FSI, for example, has a top speed of 136mph and can cover the 0-62mph dash in just 9.6 seconds. And yet CO2 emissions of just 180 g/km put it into the 19% BIK band. Most impressive of all are the economy figures: 28.5mpg on the urban cycle, 52.3mpg on the extra-urban and a combined figure of 39.7 mpg are the kind of figures a diesel would be proud to claim.
FSI? In essence it's a form of direct petrol injection, and it has been hailed as the most significant step forward for the petrol engine since fuel injection itself replaced the carburettor. But it is also a piece of intelligent thinking, about the time-hallowed principles of creating and igniting the fuel-air mixture inside the combustion chamber, in particular when running under part-load or with the throttle closed.
Most engines work on the principle that an even - or 'homogeneous' - mixture of fuel and air, at the correct proportion, is the ideal for combustion. And so it is, especially if full power is required, for example when accelerating. But how much of the time are we accelerating? What happens under a trailing throttle, for example when slowing for a junction or holding station in traffic? Audi's engineers discovered that under those conditions having a homogeneous fuel-air mixture could be wasting energy, and thus fuel.
At such times the FSI engine switches to something called a 'stratified' charge, where the injector releases a precisely-timed and directed smaller charge of fuel, creating a variable mixture of fuel and air that is at its richest around the spark plug, for instantaneous combustion, but that becomes leaner further away from the spark. Result? Enough power for the situation and a clean, highly efficient burn. In simple terms, this means that the driver has all the power he or she needs, whenever it is needed, but that the engine smoothly and seamlessly switches to a leaner burn mode whenever the car is in a steady-state cruise or is decelerating.
At the heart of the FSI engine is an Audi-developed fuel injection system, which is able to control, precisely, the timing and duration of each charge. This calls for common rail injection with a range of operating pressures from 40 to 110bar so that the amount of fuel and timing of each injection can be accurately delivered. A tumble flap in the intake manifold, to create a healthy vortex of swirling air as it enters the combustion chamber, and a specially-shaped piston crown together create the ideal combustion conditions for both homogeneous and stratified mode.
Unlike other methods of combining 'small engine' economy with 'big engine' performance, the switch between homogeneous and stratified FSI modes is all-but-undetectable by the driver, with each press of the throttle pedal being met with crisp, instantaneous response. Currently, Audi's FSI engines range from the 1.6 FSI offered for the A2 through to an all-new 3.2 litre FSI engine that may be specified for the new A6. In each case the Audi FSI engine has all the refinement and performance that the most demanding driver could wish for, whilst offering frugal economy and low Co2 emission figures. Although FSI is designed to run efficiently on ultra-low sulphur unleaded petrol, which is available throughout the UK, use of the new environmentally-friendly sulphur-free fuel will provide further bonuses in both fuel economy and 'lean burn' performance.
There is, of course, one further Audi engine that features FSI, but it is not available to the company car buyer, and nor would it impress around the M25 during rush hour. The Audi UK R8, fresh from its triumph at the 2004 Sebring 12 hours, will be attempting to claim the top step of the Le Mans podium for a 4th time this June, powered as before by a twin-turbocharged Audi V8 FSI engine producing around 610PS. Thanks to Vorsprung durch Technik, their victory could be your gain.
B7 RS4 Avant Sprint Blue/Black Recaros: Carbon Ceramic Brakes, Tech pack, Double Glazing, Solar Roof and Stuff
Sold
92 S8 D2 Ebony Black Pearl/Sable Grey
02 TT 3.2 DSG Avus Silver/Silver
01 RS4 B5 Avus Silver/Black
98 S8 D1 Jasper/Black
Sold
Users browsing this forum: Google [Bot] and 116 guests
