driveshaft
driveshaft
i need a driveshaft just wondering where the best place to get one is before i ring tps
Re: driveshaft
Why are you replacing it? I have a vert small vibration over 100mph (bearing related) and apparently the solution from Audi is to replace the whole driveshaft. JHM sells the support bracket with the bearing:
https://jhmotorsports.com/driveshaft-su ... 4-rs4.html
But I don't know anyone that can rebalance the whole thing once replaced.
Br,
V.
Br,
V.
Re: driveshaft
Long as you you mark an line up everything as you go it shouldn't need balancing, i have done there centre bearing on my prop-shaft its not the easiest thing.
But if you mean drive shaft cant you just get a cv joint?
A new drive shaft is £600 qwid!
Re: driveshaft
A company like these can likely rebuild and balance one
https://www.driveshaftuk.com/
http://www.propshaft-services.co.uk/
They both do dynamic balancing
