FAULT CODES advice please anyone !
ok a number of fault codes have came back from my car, for those who are not aware of my issue please read my other post first but in short some days my car will start perfectly fine, some days when I have a warning light showing the car will turn over but not start up. All this has been explained in my previous post so I wont bore you with all that.
So these faults, very strange, some faults showing I have absolutely no issue with ?? so those I cant understand, and only 3 I would say could possibly be the fault but again I really don't think so but that's why im asking for advice, I will show the results of 3 scans, explain what I think below each and if anyone can advise then please do.
1ST SCAN ENGINE OFF / IGNITION ON
i wont list the full scan, so first faults are as :
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul ECE 0907
Coding: 00021
Shop #: WSC 06335
VCID: 3D7F3928375649A2FE-4B18
2 Faults Found:
02745 - Bulb for Daytime Running Light; Left
30-00 - Open or Short to Plus
02746 - Bulb for Daytime Running Light; Right
30-00 - Open or Short to Plus I am aware of this as ive not replaced the upgraded bulbs just yet
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 983 C HW: 8E0 920 983 C
Component: KOMBI+WFS 4 H14 0100
Revision: 0100 Serial number: 00000000000000
Coding: 0023448
Shop #: WSC 54516 001 1048576
VCID: 2F631360BD3AAB327C-5178
3 Faults Found:
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
01321 - Control Module for Airbags (J234)
01771 - Control Module for Headlight Range (J431)
004 - No Signal/Communication - Intermittent ok the bottom one CMR is the actual light that when shows on my dash the car will not start BUT this fault if indeed was the issue would not stop the car starting up, so I can only assume this is showing because the light does/has shown up on my dash previously so that doesn't help matters really, no idea what ECM does and would this stop my car starting ? and the CMA again would not stop my car starting.
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0023448
3 Faults Found:
004 - No Signal/Communication - Intermittent all 3 faults showing again
Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
Part No SW: 8E0 035 192 K HW: 8E0 035 192 K
Component: RNS-E HIGH EU H73 0650
Revision: 02S Serial number: AUZBZ7F1169935
Coding: 0309113
Shop #: WSC 02197 785 00200
VCID: 2C59046C8C2CD02A59-51B2
3 Faults Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 7
Fault Frequency: 3
Reset counter: 62
Time Indication: 0
Date: 2017.03.22
Time: 09:06:17
Freeze Frame:
Voltage: 12.30 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
00862 - Antenna for GPS Navigation (R50/R52)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 114
Reset counter: 57
Time Indication: 0
Date: 2018.09.07
Time: 11:11:12
Freeze Frame:
Mileage: 655350 km
Count: 65535
Clock: 255:255
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
Freeze Frame:
Fault Priority: 5
Fault Frequency: 61
Reset counter: 58
Time Indication: 0
Date: 2017.04.28
Time: 16:05:58
Freeze Frame:
Mileage: 655350 km
Count: 2110
Clock: 09:34 ???????????????????????? ERM NO IDEA WHY THESE ARE SHOWING i have no issue with any of these, very strange
Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb
Part No: 8E0 959 433 CH
Component: Komfortgerát T3B 4135
Coding: 07919
Shop #: WSC 06335
VCID: 79F7ED3863FEB58292-4B18
Subsystem 1 - Part No: 8E2959802E
Component: Tõrsteuer.FS BRM 0706
Subsystem 2 - Part No: 8E2959801F
Component: Tõrsteuer.BF BRM 0606
Subsystem 3 - Part No: 8E0959801E
Component: Tõrsteuer.HL BRM 0606
Subsystem 4 - Part No: 8E0959802E
Component: Tõrsteuer.HR BRM 0606
2 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01366 - Opened Due to Crash Signal
36-10 - Open Circuit - Intermittent Alarm has only ever gone off once when a mountain bike was stolen from the bike rack on the back of my car, no idea what the crash bit is all about ?
Address 56: Radio Labels: 8E0-035-192-RNSE.clb
Coding: 0309113
3 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 62
Time Indication: 0
Date: 2017.03.22
Time: 09:06:17
Freeze Frame:
Voltage: 12.30 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
Freeze Frame:
Fault Priority: 5
Reset counter: 57
Time Indication: 0
Date: 2018.09.07
Time: 11:11:12
Freeze Frame:
Mileage: 655350 km
Count: 65535
Clock: 255:255
Freeze Frame:
Fault Priority: 5
Fault Frequency: 61
Reset counter: 58
Time Indication: 0
Date: 2017.04.28
Time: 16:05:58
Freeze Frame:
Mileage: 655350 km
Count: 2110
Clock: 09:34 AGAIN, i dont sem to have any of these issues so why are they showing ?
Address 65: Tire Pressure Labels: 8E0-907-273.lbl
Part No SW: 8E0 907 273 A HW: 8E0 907 273 A
Component: Reifendruck 3 H04 0130
Coding: 0022523
Shop #: WSC 02195 823 21170
VCID: 2A55027486D8CE1AAB-5178
1 Fault Found:
01521 - Sensor for Tire Pressure
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 3
Fault Frequency: 48
Reset counter: 40
Time Indication: 0
Freeze Frame:
(no units): 70.0
Voltage: 13.40 V
(no units): 61.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn. again this seems to work fine, when dash light says top up tyre pressures i do, all seems to work fine, no idea again why these are showing
SO THAT WAS SCAN 1 ingnition on engine not running, scan two next
Coding: 00021
Shop #: WSC 06335
2 Faults Found:
Coding: 0023448
3 Faults Found:
Coding: 0023448
3 Faults Found:
Coding: 0309113
3 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 62
Time Indication: 0
Date: 2017.03.22
Time: 09:06:17
Freeze Frame:
Voltage: 12.30 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
Freeze Frame:
Fault Priority: 5
Reset counter: 57
Time Indication: 0
Date: 2018.09.07
Time: 11:11:12
Freeze Frame:
Mileage: 655350 km
Count: 65535
Clock: 255:255
Freeze Frame:
Fault Priority: 5
Fault Frequency: 61
Reset counter: 58
Time Indication: 0
Date: 2017.04.28
Time: 16:05:58
Freeze Frame:
Mileage: 655350 km
Count: 2110
Coding: 07919
Shop #: WSC 06335
2 Faults Found:
35-00 - -
Coding: 0309113
3 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 62
Time Indication: 0
Date: 2017.03.22
Time: 09:06:17
Freeze Frame:
Voltage: 12.30 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
Freeze Frame:
Fault Priority: 5
Reset counter: 57
Time Indication: 0
Date: 2018.09.07
Time: 11:11:12
Freeze Frame:
Mileage: 655350 km
Count: 65535
Clock: 255:255
Freeze Frame:
Fault Priority: 5
Fault Frequency: 61
Reset counter: 58
Time Indication: 0
Date: 2017.04.28
Time: 16:05:58
Freeze Frame:
Mileage: 655350 km
Count: 2110
Coding: 0022523
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 48
Reset counter: 40
Time Indication: 0
Freeze Frame:
(no units): 70.0
Voltage: 13.40 V
(no units): 61.0
Not Recogn.
Not Recogn.
Not Recogn.
- Attachments
- Log-101-WUAZZZ8EX7N905086-219270km-136248mi.txt
- (9.67 KiB) Downloaded 95 times
Sprint Blue RS4 - 20" X 10J 3DSM Wheels - Carbon Front Splitter - Carbon Rear Diffuser - H & R Anti Roll Bars - Bilstein Adjustable Shocks - Milltek Exhaust System - De Catted - Valve Removed - MRC Stage 2 Re-Map - 480 bhp
Re: FAULT CODES advice please anyone !
2ND SCAN ENGINE RUNNING...
basically showing the same as scan 1
ALL CODES WERE THEN CLEARED and re scanned for a 3rd time
BASICALLY, all faults came back and showing the same as first scan I think, so what is my next move ?????
remembering that since I have removed the upgraded bulbs, the car has started up every day for the last 4 or 5 days without any issue but that could be the intermittent fault so I cant assume anything at the moment so still no the wiser
I think 01314 is the fault code to focus on at the moment. Have a read of this http://wiki.ross-tech.com/wiki/index.php/01314
Let me know how you get on.
EDIT: Also address 01 02 03 didn't scan (maybe others as well, I can't remember)
ok I will have a read and look into it, not sure where about's this module is but will try and find out on you tube or something, Currently the car is running fine as you know so its a case of will it wont it do it again now
The last time I saw as many error codes as that was when my battery was failing. Do you know the last time it was changed?
If it is not the battery then looks like you have major electrical issues there.
Possibly a wiring loom fault?
Misano Red RS4 B7 Avant
ok update.....
I was about to say since removing the lights, the car has been perfect UNTIL TONIGHT, couldn't unlock / lock car on button, once inside alarm went off and once put the key in ignition the alarm stopped BUT car now has that issue again and will not start up ???
Is this now pointing towards the immobiliser ??? and if so is that a complete engine module replacement ??? A few keep mentioning the battery, and obviously I cant say its not BUT it is a new one from only last year and there is plenty of juice allowing the car to turn over, and once this light on the dash is no longer showing the car does indeed fire up so I cant see how its the battery personally but I cant rule it out either but I have no reason to think this is battery related, I am getting F****ED OFF now though
Honestly, I'd charge the battery and see how you get on.
I've had a few problems starting mine recently but fingers crossed, after fitting a new battery it's been OK.
The battery I replaced was less than 2 years old and probably didn't need changing, just a good charge.
Mike
Sent from my PRA-LX1 using Tapatalk
Mike
ok but even when the battery has full power ???mikep99 wrote: ↑Mon Oct 29, 2018 11:52 pmHonestly, I'd charge the battery and see how you get on.
Mike
I have seen a few you tube videos, apparently there are 2 or 3 relays under the ecu which can stop cars starting on the a4 b7, BUT where is the ecu on a RS4 ?
I'd start with charging the battery, at least you can eliminate that if you still have problems.
Start with the simple stuff...
Also, have a read of
viewtopic.php?t=129927
car started first time this morning ???? WTF lol but yes ok understood, will remove it and fully charge it when I get chance....
QUESTION ????
If its battery, and when this fault happens again, if I jump the car with leads from my van, and the car starts would that then point to battery ??? or will this not have the same affect as charging the battery ? just a thought that's all
QUESTION ????
Remember jump leads, from a vehicle with engine running, give a lot more voltage than a battery when driving a starter.
So yes, if that happened it may well indicate a weak battery.
ok lets go with that one then next time this happens, which im guessing will be later today or tomorrow lol, not sure why im laughing though, I feel like I want to kill someone or something ie the car
Point of caution with regards to the battery. Prior to clearing the fault codes the car started no problem, we then cleared the fault codes and then started the car again with no problem and then re-scanned giving the 3rd set a scan results. So in my mind the battery seamed to be OK although but there were a shed load of fault codes on the 3rd scan appearing after a clear out
Users browsing this forum: Bing [Bot], Google [Bot], Zyox and 252 guests
