06 RS4 B7 creaking at slow speed right side
geoffrcox
Post by geoffrcox » Wed Sep 26, 2018 6:00 pm
Hi Guys
I have just had a creaking come on the right side when i turn the steering wheel its only at slow speed, turning left no issues.
Regards
Pistolpete2543
Re: 06 RS4 B7 creaking at slow speed right side
Post by Pistolpete2543 » Wed Sep 26, 2018 9:54 pm
Worn tie-rod or a suspension bush on its way out possibly.
geoffrcox
Post by geoffrcox » Thu Sep 27, 2018 8:28 am
Thanks for your reply. Could it be DRC?
Pistolpete2543
Post by Pistolpete2543 » Thu Sep 27, 2018 11:03 am
It doesn't sound like the symptoms of DRC failure which would be more of a knocking/rattling over bumps. However, easy enough to check for oil residue on your dampers or leaks on the DRC pipework suggesting loss of pressure.
A creak is more likely to be a suspension or steering bush, tie rod or possibly the rack itself
geoffrcox
Post by geoffrcox » Thu Sep 27, 2018 12:46 pm
Thank you . Very helpful
Shockerboy
Trader (Expired)
Post by Shockerboy » Mon Oct 08, 2018 8:36 am
Hi rthere , I replace a lot of DRC systems and i have experienced Creaking from one of the DRC shocks , it was almost out of oil and the inner shaft Piston seal had overheated and made a creak , there will be signs of oil everywhere however . If not definately worn Suspension or steering component .
Another simple problem is Dirt and debris from the road sitting in the spring seat and scratching against the Spring seat or spring , simply spray WD 40 around the spring top and bottom seat . its no cost and could tell you where the issue is ( or isnt of course )
Users browsing this forum: No registered users and 353 guests
