My B6 Supercharged Stage 1+ RS4 build thread...
J130YCE
Re: My B6 Supercharged Stage 1+ RS4 build thread...
Post by J130YCE » Fri Nov 24, 2017 11:47 pm
Im running 620...
BMW M2 Comp
RS4 Supercharged
Current Abarth 500c Two tone Grey and Mint - a modified go-cart.
Current T5 180 bi-turbo - modified, Reimo pop top, ABT kit, Caravelle 7 seats, going on 'air' this summer
Gone RS4 B7 Avant MRC, MK5 R32, 205 GTI, Mk1 golfs... plus some other poor souls
iconic78
Post by iconic78 » Fri Nov 24, 2017 11:53 pm
J130YCE wrote:Im running 620...
You should be able to push that higher by lowering your IAT’s.
Have you run any logs?
J130YCE
Post by J130YCE » Fri Nov 24, 2017 11:57 pm
No, but its at MRC as i write.... now is the time!?
BMW M2 Comp
RS4 Supercharged
iconic78
Post by iconic78 » Sat Nov 25, 2017 10:07 am
J130YCE wrote:No, but its at MRC as i write.... now is the time!?
You can run logs anytime through VCDS and a. Ross tech cable.
I would suggest you dyno the car before and after, as most SC tunes run rich(for safety). Running lower IAT’s allows you dial back on the timing and mixture therefore making it more efficient and producing more power.
Did you get my messages?
J130YCE
Post by J130YCE » Sun Nov 26, 2017 9:25 pm
Yes, thanks, I have emailed Joe.
Thanks very much for the information
BMW M2 Comp
RS4 Supercharged
m2motortechnik
Post by m2motortechnik » Mon Jan 29, 2018 11:24 pm
iconic78 wrote:
Tue Sep 19, 2017 8:30 pm
So after a long and very hot summer(62c was the hottest) now finishing everything off on the car before we move countries. The car of course is coming with.
Ok so had it Dyno’d at 670ps and now I’m uprating the LPFP to a 340 LPH in anticipation of having a built engine to have a crack at getting close to the magic 800!
I’ve already previously replaced the HPFP’s for uprated units.
Will be reflashing the ecu again. Also fitting a Killer Chiller to reduce IAT’s.
The remaining bodywork will be completed before the end of the month. As that’s when the car is being shipped. ImageImageImageImageImage
where is the dyno print out ?can you post it ?
Users browsing this forum: Google Adsense [Bot] and 149 guests
