New member looking for knowledge
NichollsRS
Post by NichollsRS » Fri Jul 07, 2017 3:29 pm
Hello,
New to the forum and on the look for a Daytona Grey B7 RS4. I'm a big estate fan, but I can't decide on an Avant or Saloon, both look really good!
Anyway, I'm looking for some advice on a couple of things. I'm aware of some common issues but other than the below is there anything I should be looking for?
- Coked engines
- leaky suspension
- Aux Radiator failing
- Something to do with cooling pipes
Service Intervals - What are the intervals? eg 2 years or 15k, which every comes first.
Service Types - Whats the routine and rough costs. eg Oil Service+filters £200 - Inspection I oil+filters, additional filters - £350 Inspection II oil,diff,gearbox - £350
Spec
Generally have no idea what these come with stock so i'm guessing this is comes as standard
Recaro full leather heated
xenons
rain sensor
Optional
Recaro shell seats
cruise control
Sat nav
bluetooth
For me, the min is xenons, heated seats, cruise control and rain sensors. Anything else will be a bonus. Any help, advice or additional info would be greatly appreciated.
Thanks,
:thumbs:
Jon_J
Re: New member looking for knowledge
Post by Jon_J » Fri Jul 07, 2017 4:18 pm
Rain sensors are not standard. Not much help but some.
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
- Full Stereo install
S5 8T Cab White
A5 Cab 3.0 TDI Phantom Black
jonytek
Post by jonytek » Fri Jul 07, 2017 6:25 pm
Saloon any day of the week.
BUILD THREAD
IG: @bad_rs_4
Post by MikeFish » Fri Jul 07, 2017 6:49 pm
Xenons are standard. There was an option for adaptive xenons who are the ones that turn as you do.
Heated front seats standard, rear outside seats optional.
Cruise control standard.
As already stated rain sensor and also auto light were optional.
irn_bru_ce
Post by irn_bru_ce » Fri Jul 07, 2017 8:39 pm
Pretty sure the satnav was also standard, although the headunit is knocking on a bit now, you can swap it for a 2012 unit from the A3, slightly better resoloution, faster CPU
There was 2 levels of suspension, supersports (SS), or super sports plus(SS+) , with the plus being a bit harder, and 10mm lower at the rear
The two types of seats are the comfort which had more adjusters, and the buckets which are more limited, usually if the original owner specified the buckets they alo went with the flat bottom steering wheel, the comforts seats usuall match up to the multi function wheel that had extra buttoms to control stuff
There was an option of ceramic 380mm front brake discs with 6 pot calipers, standard is 365mm steel discs with 8 pot calipers
There were 4 interior trims, most are carbon, some are brushed alloy or piano black wood, rarest is walnut, rare because to most people the walnut is a weird choice for such a sporty car
There were a few extras that don't matter much to most people, such as the ski bag for the through hole in the rear backrests, the fridge liner for the glove box, sunroof etc
Post by MikeFish » Fri Jul 07, 2017 8:54 pm
Sat nav was an option but almost all cars have it now although there was 20,000 mileage car discussed here last week that didn't have it.
Covkiller
Post by Covkiller » Tue Jul 11, 2017 9:49 pm
Man alive you definately need heated seats if they're outside, brrr. :jump_clap:
Matty
Post by Matty » Tue Jul 11, 2017 9:59 pm
:lol: :biggrin3:
2007 Black RS4 Avant | Black Optics | Pioneer AVIC-F20BT Navigation AV System | Full Interior / Exterior LED Kit (Trups) | 19" Team Dynamics Le Mans Gloss Anthracite Alloys | 12mm Bimecc Hubcentric Spacers all round
dougle_turbo
Post by dougle_turbo » Tue Jul 11, 2017 10:46 pm
Oil cooler and pipes will need doing at some point (the cooler and pipes are different metals and therefore corrode rapidly once water ingress occurs). Lots of threads on this.
Aux rads tend to collect debris, which then gets damp and causes failures. The left one can be removed for a cold air feed. Again lots of threads on this.
DRC leaks can occur, look for a car that's had them replaced at some point. If not it's likely they will need to be at some point. Again lots of threads.
Coked engines and carbon cleans are a very highly discussed topic. Some see it as essential, others as a waste of money. One thing is for sure, the carbon build up will start again as soon as the clean has been completed. Even more threads on this.
Hope some of that helps.
2010 987 Cayman S.
Clio 172 Cup track car "Nicole" aka NV2 Sold
Clio 172 Cup track car "Nicole" aka NV1 - R.I.P
2007 Phantom black RS4 avant - with added ceramics. Sold
2006 Phantom black RS4 saloon. Sold
1990 Black Audi S2 (3B) - full engine rebuild. Sold
1981 Black Porsche 924 Turbo, rescued from under a tree and restored. Sold
