Revs not quite right
vroomrs4
Post by vroomrs4 » Sun Mar 19, 2017 1:21 pm
Hi all
When I put my foot down on the excelerater The revs go up as normal but then when I take my foot off the revs hangs there for couple seconds which doesn’t feel right, has anybody else had this problem,
Someone said it could be the clutch switch.
Advice much appreciated.
dizziebug
Re: Revs not quite right
Post by dizziebug » Sun Mar 19, 2017 1:22 pm
We have the same problem - changed the switched no change changed the MAF sensor its fixed other things but not that
dizziebug
Post by dizziebug » Sun Mar 19, 2017 1:23 pm
Switches sorry
nij
Post by nij » Sun Mar 19, 2017 2:25 pm
It might be the PCV valve as it will have perished over the years, it's mounted under the carbon fibre RS engine cover.
Phantom Black R8 V10 plus, Capristo Exhaust
Phantom Black (B7) RS4 Saloon, MRC Stage 2
Mercedes E-Coupe 350CDi
dizziebug
Post by dizziebug » Sun Mar 19, 2017 4:10 pm
Good suggestion
vroomrs4
Post by vroomrs4 » Sun Mar 19, 2017 4:22 pm
Great, i'll have a look at that.. Thank you
Dantheman84
Post by Dantheman84 » Tue Mar 21, 2017 9:56 pm
Yes best way to test pvc is remove you oil filler cap with engine
Running if it bogs done and almost cuts out your valve if definitely faulty hope this helps
RS4 kw v3 full miltek no cats :nogarors4:
Intake spacer deflap stage 2 flat shift launch
Kawasaki ZX10R 197bhp :audibash:
vroomrs4
Post by vroomrs4 » Wed Mar 22, 2017 9:19 pm
Thanks for that tip..
Dantheman84
Post by Dantheman84 » Wed Mar 22, 2017 9:28 pm
No worries I know this cuz mines has failed last week so in the process of stripping down and carrying out carbon clean too
Also I have ordered spaces for inlet manifold that's ment to
Make a difference too so we will see
Stigaream
Post by Stigaream » Sat Jan 06, 2018 8:38 pm
Did you find out what was wrong ?
rs user
Post by rs user » Sun Jan 07, 2018 1:05 am
are you sure? read elsewhere on here that the rs4 b7 still does that with a new valve fitted? .... :beerchug:
Seattle-squash
Post by Seattle-squash » Sun Jan 07, 2018 7:17 am
Based on my experience, yes it still bogs down some but far quicker recovery and although mine did not shut down engine when it failed/was replaced, it almost stalled. So before and after was still noticeable different, upon change.
