Bluetooth
MarkV8
Bluetooth
Post by MarkV8 » Sat Aug 20, 2016 8:42 pm
Hi guys is thair anyway I can comely bluetoth to my sound system in my rs4 it has nav TV card slots I'm just not sure if at all possible ?
MarkV8
Re: Bluetooth
Post by MarkV8 » Sun Aug 21, 2016 7:18 pm
Bump
toyneg
Re: Bluetooth
Post by toyneg » Mon Aug 22, 2016 10:57 am
you can have Bluetooth but if you want an original Audi BT set up you will need to buy an updated 3G head unit and then separate bluetooth module http://vwcruise.com/RNS-E-3G-Pics.html . other options are 3rd party kits such as Parrot.
MarkV8
Re: Bluetooth
Post by MarkV8 » Sun Aug 28, 2016 10:07 pm
I was hoping thaire would be a way with the existing head unit but it is looking like as u say a new head unit thanks for ur help.
Surrey Sam
Re: Bluetooth
Post by Surrey Sam » Sun Aug 28, 2016 11:11 pm
If it's just the Bluetooth telephone function you require, then that module will work with the original RNSe fitted to the car from factory.
Just need module, wiring harness, microphone, VCDS coding and some DIY skills.
MarkV8
Re: Bluetooth
Post by MarkV8 » Sun Aug 28, 2016 11:42 pm
I tryde to conekt to it the other day as I want to play my I phone through it eg musick. After 4 attempts with ignition on the word Bose poped up on my phone but my phone timed out and I can't get Bose back up the head unit does have a phone function it just said phone is not connected, do u no or have a thread that can make thiss function work with thiss head unit chears Surrey Sam
Surrey Sam
Re: Bluetooth
Post by Surrey Sam » Mon Aug 29, 2016 12:12 am
You cannot stream any music via the OEM Bluetooth phone connection unfortunately. Playing music utilises a profile called A2DP which the factory Bluetooth module doesn't support, whereas the handsfree and Sat Nav uses a profile called HFP which the Bluetooth does support.
Instead, you'll have to wire in to the AUX input - an A2DP module and connect to that instead for music.
MarkV8
Re: Bluetooth
Post by MarkV8 » Mon Aug 29, 2016 12:43 am
Top man Sam I'm gunna get on the case and get it sorted I'm sick of listening to the same cd's lol
MarkV8
Re: Bluetooth
Post by MarkV8 » Mon Aug 29, 2016 12:46 am
MarkV8 wrote:Top man Sam I'm gunna get on the case and get it sorted I'm sick of listening to the same cd's lol
Sam is thiss a2 dp connection on the back of the head unit mate
Surrey Sam
Re: Bluetooth
Post by Surrey Sam » Mon Aug 29, 2016 8:27 am
There is no connection. By retrofitting the AUX input you're effectively creating the point for you to connect a 3rd party A2NP module into the system.
MarkV8
Re: Bluetooth
Post by MarkV8 » Mon Aug 29, 2016 8:01 pm
Ah right ok I'm with u use best get busy and get on with it cheers Surrey Sam .
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 188 guests
