Bluetooth
Re: Bluetooth
you can have Bluetooth but if you want an original Audi BT set up you will need to buy an updated 3G head unit and then separate bluetooth module http://vwcruise.com/RNS-E-3G-Pics.html . other options are 3rd party kits such as Parrot.
Re: Bluetooth
I was hoping thaire would be a way with the existing head unit but it is looking like as u say a new head unit thanks for ur help.
- Surrey Sam
Re: Bluetooth
If it's just the Bluetooth telephone function you require, then that module will work with the original RNSe fitted to the car from factory.
Just need module, wiring harness, microphone, VCDS coding and some DIY skills.
Re: Bluetooth
I tryde to conekt to it the other day as I want to play my I phone through it eg musick. After 4 attempts with ignition on the word Bose poped up on my phone but my phone timed out and I can't get Bose back up the head unit does have a phone function it just said phone is not connected, do u no or have a thread that can make thiss function work with thiss head unit chears Surrey Sam
- Surrey Sam
Re: Bluetooth
You cannot stream any music via the OEM Bluetooth phone connection unfortunately. Playing music utilises a profile called A2DP which the factory Bluetooth module doesn't support, whereas the handsfree and Sat Nav uses a profile called HFP which the Bluetooth does support.
Instead, you'll have to wire in to the AUX input - an A2DP module and connect to that instead for music.
Re: Bluetooth
Top man Sam I'm gunna get on the case and get it sorted I'm sick of listening to the same cd's lol
Re: Bluetooth
Sam is thiss a2 dp connection on the back of the head unit mateMarkV8 wrote:Top man Sam I'm gunna get on the case and get it sorted I'm sick of listening to the same cd's lol
- Surrey Sam
Re: Bluetooth
There is no connection. By retrofitting the AUX input you're effectively creating the point for you to connect a 3rd party A2NP module into the system.
Re: Bluetooth
Ah right ok I'm with u use best get busy and get on with it cheers Surrey Sam .
Users browsing this forum: 666Lenine and 196 guests
