Throttle hanging.
boombastik
Throttle hanging.
Post by boombastik » Sat May 21, 2016 8:06 pm
Used the car tonight. First time in over a week and it felt like the revs were hanging when changing gear
I'm certain it's not done this before any one any ideas
RS4 B7 Saloon Milltek Cat back, CAF with piper cross panel, Wrapped optics black, Satin black wheels, TRUPS LED front DRL's & sides, goodridge braided hoses, H&R 10/15mm spares front/rear
Bilstien B16 coilovers with H&R anti roll bars
MRC stage 2 deflapped, precat gutted 439ps 481nm torque
1/4 mile time 12.884sec
My clutch replacement write up can be found here viewtopic.php?f=35&t=116929&start=15
Seattle-squash
Re: Throttle hanging.
Post by Seattle-squash » Sat May 21, 2016 8:39 pm
And it's not your clutch I take it? Sorry not had that problem yet but curious, maybe a coding of the throttle body/ecu.
Post by MikeFish » Sat May 21, 2016 8:40 pm
Isn't that one of the symptoms of a dodgy clutch switch? Does your cruise control still work?
RichieRS
Post by RichieRS » Sat May 21, 2016 8:46 pm
MikeFish wrote:Isn't that one of the symptoms of a dodgy clutch switch? Does your cruise control still work?
Straight away thought the same as Mike I this!!.
This was my first noticeable syptom and then shortly found out the cruise wasn't working followed by the fact to start the car required holding the start button instead of 1 touch start!!
boombastik
Post by boombastik » Sat May 21, 2016 9:15 pm
Never tried the cruise.
The clutch is all new but the switch isn't. I'll have a look would it throw up a code if it was
Pistolpete2543
Post by Pistolpete2543 » Sat May 21, 2016 9:20 pm
I've just replaced clutch & slave cylinder etc. Clutch switch no longer working as have to hold start button and no cruise control. I guess once removed they aren't reusable so I need a new one.
Post by MikeFish » Sat May 21, 2016 9:27 pm
They are about £17 each. There is an upper one and a lower one and take minutes to replace.
I took mine out oncemo play with when there was nothing wrong with it and broke it then got an error code but I believe they can stop working without codes too. I'm not 100% but I think its your top one that's gone as that's the one that detects you are pressing the clutch to change gear; you don't normally press the clutch all the way to the bottom on a gear change so the lower switch makes no difference to gear changes or cruise control.
RichieRS
Post by RichieRS » Sat May 21, 2016 10:33 pm
If you do replace them. Make sure you have a read of the thread that's on here about refitting them properly. Lots of people have broken them whilst trying to install them by not fitting them the correct way.
Will see if I can find the procedure for you!!
RichieRS
Post by RichieRS » Sat May 21, 2016 10:36 pm
IOMMAN
Post by IOMMAN » Sun May 22, 2016 8:05 am
I replaced both the top and bottom clutch switchs on mine and it stopped the revs from hanging + plus my one push start and cruise control started working
An easy cheap fix but don't break the new switchs - the online guide is helpful
2006 Audi RS4
2020 Audi Q2 SLine Black Edition Quattro TFSI40
2010 Land Rover Discovery 4 HSE
ashy
Post by ashy » Sun May 22, 2016 10:44 am
Make sure you get genuine audi too as I bought pattern as thought they would be cheaper :bash: ( which they weren't ) and got the cruise back but still had the hanging idle. Bought genuine and problem solved. :beerchug:
boombastik
Post by boombastik » Mon May 23, 2016 6:55 am
took the car to work this morning and the cruise was working but while it was on it switched off and the throttle started hanging again
RS4_Ollie
Post by RS4_Ollie » Mon May 23, 2016 5:49 pm
Could be your MAF?
Post by MikeFish » Mon May 23, 2016 6:21 pm
With hanging and cruise issues I'd be amazed if it wasn't the clutch switch.
RS4_Ollie
Post by RS4_Ollie » Mon May 23, 2016 7:16 pm
ah read his post wrong, thought it said he switched it off and then had hanging, not it switched off, sorry
Users browsing this forum: No registered users and 254 guests
