I've noticed my car has a slight knock from what sounds like the off side rear suspension. It only seems noticeable on a cold start for the first few miles, then it disappears.
The rear also seems to be a tad lower than it has been. It's not too evident, I've just noted that my pressure washer's lance is recently a bit closer to the bodywork when cleaning the arches. I haven't had the wheels off to check for any seepage.
I haven't noticed a detrimental affect in handling, but if it's a gradual change, it could be forgivable for not noticing any change.
My car has just ticked over 80k miles, and to date the original DRC shocks haven't given any trouble. Considering this, I have wondered if (and when) they will give out.
I don't wish to go the coilover route, nor am I keen to go for a repair. I'm sure those routes good, but I'm just after a straight swap for new warranted items from my main dealer.
My car has the Sports Suspension Plus, so is there any difference in the shock of which I should be aware?
I know they are to be replaced in diagonal pairs, so should I be preparing myself for a large bill, or could my symptoms be something else?
If it the shocks, is anything else worth replacing while the mechanics are there? (I'm thinking springs and rubber bits.)
Any and all thoughts and suggestions are welcomed by you guys
Thank you.
Darren
