Breather system
bond1407
Breather system
Post by bond1407 » Fri Apr 01, 2016 7:23 pm
been on a very long journey with my rs4 one that is hopefully nearing the end, from a bodged carbon clean to a bolt entering the combustion hopefully i'm close just hoping someone on here can help me finish off. its been nearly 6 months since the car was dismantled and I've put it all back together where I think everything goes (please bare in mind I did not take it apart) can someone shed any light on the breather pipes which go to the throttle body, I've got a pipe to one breather outlet but I cant see a pipe for the other one, maybe it doesn't have one?? basically can someone have a quick gander at theirs and tell me where I've either gone wrong or say yes that's right, pictures would be amazing or a diagram as to where they should all go so I know I've gone the right way. touch wood you kind people on here will save me a headache!! thanks in advance
Lukes3
Re: Breather system
Post by Lukes3 » Fri Apr 01, 2016 7:36 pm
I dont mind having a look but im not sure what pipes you mean? Have you got a picture you could post?
bond1407
Re: Breather system
Post by bond1407 » Fri Apr 01, 2016 7:42 pm
On the throttle body itself there's one small outlet pipe on the side and one at the bottom I just need to know if both these should have a breather attached as I only have one spare pipe I can grab a picture when I'm home
Lukes3
Re: Breather system
Post by Lukes3 » Fri Apr 01, 2016 8:38 pm
Yes grab a picture if you can. i can remember the bottom one,but Carnt the side one. but qwick guess i wud say there both breathers as nothing else will go to it.
RichieRS
Re: Breather system
Post by RichieRS » Fri Apr 01, 2016 8:43 pm
Are these the 2 you speak of?
Lukes3
Re: Breather system
Post by Lukes3 » Fri Apr 01, 2016 8:51 pm
There the ones i was thinking but thats the inlet pipe?
bond1407
Re: Breather system
Post by bond1407 » Fri Apr 01, 2016 9:11 pm
Yes I've got that one but on the back of the throttle body nearest the bulk head there's an out let and one underneath
bond1407
Re: Breather system
Post by bond1407 » Sat Apr 02, 2016 10:19 am
I got it slightly wrong the outlets are on the inlet manifold not the throttle body, you can see the bottom one with nothing attached and the side one with the yellow round the pipe, ive done some digging and I think this pipe goes to the bottom one and the side one should be blanked off which would make more sense as to why I have nothing for this outlet
Lukes3
Re: Breather system
Post by Lukes3 » Sat Apr 02, 2016 10:29 am
Yes yellow has a bung on it An the bottom one goes under the manifold.
Lukes3
Re: Breather system
Post by Lukes3 » Sat Apr 02, 2016 10:40 am
Not sure if this is any good for you?
Covkiller
Re: Breather system
Post by Covkiller » Tue Apr 05, 2016 10:45 pm
Maybe this may help, page 22 at a quick glance:
http://www.s4-mtm.com/images/RS4V8-StudyGuide.pdf
koolade9
Re: Breather system
Post by koolade9 » Wed Apr 06, 2016 5:55 pm
Bottom port connects to the purge valve. It looks like you've got that currently connected to the rear port on the IM, so swap that line. The rear-most port should be capped.
Users browsing this forum: No registered users and 159 guests
