Misfire under full throttle
Rs-mad-burfy
Post by Rs-mad-burfy » Sat Jun 20, 2015 2:58 pm
Hello,
I'm getting a misfire, noticeably in 6th gear when the revs get to around 3500 when peddle is right down! It's not a constant, there's no rethumn to it.
Any ideas? No warning lights on.
Andy
NJMAudiRS4
Re: Misfire under full throttle
Post by NJMAudiRS4 » Sat Jun 20, 2015 6:06 pm
Could be a number of issues but your usuall suspects are, Coil pack starting to loose the will to live, possible spark plug starting to fail, MAF sensor dirty or breaking down.
Is your car standard ? Have you had a remap ? What fuel are you using ?
Another possibility could be a vac leak
These are all things you can check by yourself with the minimum of mechanical nounce. Use the search function button and it can help you find all the info needed
I hope you get it sorted
GlenRS
Post by GlenRS » Sat Jun 20, 2015 6:07 pm
Some sort of ignition break down under compression. Check your spark plugs and then coil packs.
VCDS should tell you which cylinder to check first.
Rs-mad-burfy
Post by Rs-mad-burfy » Sat Jun 20, 2015 8:27 pm
Thanks guys I'll check it out and let you know!
Thanks again
Andy
R1RS4
Post by R1RS4 » Sat Jun 20, 2015 9:21 pm
Do you have vcd's?
First check if any faults show or they do not clear down
If they do clear down ie not showing any faults
Do a search on engine misfire/misfiring
I had the same thing and it took many hours to resolve
Any other things not quite right with the way in which it runs?
Good luck
RS4 B7 Avant,2007
Metallic black, Black optics pack, Black gloss Wheels, Milltek black tipped -valved, MRC Installed TTS Supercharger 610ps/626nm, MRC stage 3 remap, CAF, DRC/SS+ with H&R spacers, carbon race splitter, carbon trim
audi_do_dat_den
Post by audi_do_dat_den » Sun Jun 21, 2015 12:00 pm
Id start with a VCDS scan, then a call to Audi to see if you missed the coilpack re-call campaign (you may well get a new set of coil packs for free)
It would be worth changing plugs also if theyve been in a while.
E14STO
Post by E14STO » Sun Jun 21, 2015 8:33 pm
I've had this twice in last 3 months, most recently this week.
Lambda sensor first time, new maf friday.
Current -
R8 V10 Plus
Previous -
C7 RS6 Merlin, JBS stg3
997 Gen2 PDK Turbo
Nissan GTR (JM900R)
B7 RS4 TTS, Sepang, black optics, ceramics, miltek, cold air feed etc etc / leon Cupra
, B5 RS4(avus), 996 GT2, B5 RS4 (Misano), TVR Cerbera 4.5, Evo VII RS Sprint
Nissan GTI-R, Uno Turbo ie
S4Player
Post by S4Player » Mon Jun 22, 2015 9:31 pm
E14STO wrote:I've had this twice in last 3 months, most recently this week.
Surely not still chewing maf's?
E14STO
Post by E14STO » Tue Jun 23, 2015 9:01 am
First one I've had since owning, 10k miles in...
I can cope with that tbh.. :-)
Current -
R8 V10 Plus
Previous -
997 Gen2 PDK Turbo
Nissan GTR (JM900R)
S4Player
Post by S4Player » Tue Jun 23, 2015 9:10 am
I was one every bloody month then it settled
E14STO
Post by E14STO » Tue Jun 23, 2015 9:25 am
It's had coil packs, lambdas, maf - so hopefully it's gonna run sweet for another 10k minimum!
Was gonna sell it this summer but a couple TTs cars up for sale so not ideal.
Sorry OP - not meant to hijack
Hope it's an easy fix as above!
Current -
R8 V10 Plus
Previous -
997 Gen2 PDK Turbo
Nissan GTR (JM900R)
Users browsing this forum: Google [Bot] and 155 guests
