Intake Manifold Flap Position Sensor (Bank 2) P2020 - 008
leadfoot
Post by leadfoot » Fri Apr 17, 2015 9:28 pm
Need some help... The following VAG code came up... I purchased the part... and using my Bentley CD... can't for the life of me find where this is...
I have found described as being located "valve is positioned near the airbox and controls the vacuum that regulates a small flap in airbox"
I am going crazy.... please help me find this in the Bentley docs... i think it is a difference in part naming.
R1RS4
Re: Intake Manifold Flap Position Sensor (Bank 2) P2020 - 0
Post by R1RS4 » Fri Apr 17, 2015 9:39 pm
The intake manifold flap position sensors are mounted on the ends of the intake manifold not the air box, the air box does not have banks
Bank 2 is the passenger side in the UK I believe
RS4 B7 Avant,2007
RS6BRIT
Post by RS6BRIT » Sat Apr 18, 2015 5:36 am
That's right it's the passenger side manifold flap position sensor. It's a manifold off job for that one iF I remember correctly, as it's mounted at the rear of the manifold. The drivers side bank 1 is at the front and is accessible without removing the manifold.
GlenRS
Post by GlenRS » Sat Apr 18, 2015 8:08 am
RS6BRIT wrote:That's right it's the passenger side manifold flap position sensor. It's a manifold off job for that one iF I remember correctly, as it's mounted at the rear of the manifold. The drivers side bank 1 is at the front and is accessible without removing the manifold.
Although even that one is a right pita to get at. But is possible... just.
R1RS4
Post by R1RS4 » Sat Apr 18, 2015 9:31 am
If you need to see what your trying to remove (your doing it yourself) I can send you a photo of the manifold upside down, (spare manifold) this will help finding the fixings,
I can also let you know what tools you will need?
RS4 B7 Avant,2007
Users browsing this forum: Bing [Bot], Google [Bot] and 2301 guests
