Tyre pressure sensors and service costs
Hi all,
Firstly, I have recently bought some Michelin pilot super sport's for the RS 4 and was wondering what the deal is with the pressure sensors. Are the sensors part of the valve or are they separate? The valves that are currently on the car appear to be slightly corroded so will need replacing but if the sensors are part of the valves, I can imagine they would be quite costly to replace?
Secondly, I am on a quest to get a service through Audi as cheap as possible, I have been quoted £150 per hour labour so far which is quite simply ludicrous considering the experiences I have had so far with 'trained Audi technicians'. Has anyone managed to get them down on this labour price? And if so, did they budge on price much?
Thanks in advance
Dan
Thanks in advance
Dan
- Silverfox42
Re: Tyre pressure sensors and service costs
Hello,
Possibly some terminology that could confuse here, but I have changed old valves within the valve housing and the TPMS is unaffected. If you mean the thread where the dust cap sits, then that would be the TPMS unit needing replacing - yes, expensive!
Service: Each stealer seems to be a law unto itself, some will come down on price if you show them an independent specialist garage labour quote, others won't. Other way is to provide your own consumables - Audi dealers can charge upto 5x the price of Oil, plugs etc, so perhaps ask if you can source your own. The RS4 takes over 10 litres of oil, but you can source the right stuff (Castrol Edge) for around £25 per 5 litre bottle, rather than pay £100 for Audi to supply it. Only difference is that on my dealer invoice, it was noted that the consumable were note Audi supplied/genuine!
Good luck!
Good luck!
Previous:
Previous:
Regarding the Tpms, I was quoted, if I remember right over £100 plus vat for each sensor from trade parts, plus another £15 plus vat for the valve stem. In the end I got 4 sensors and stems from a guy on eBay delivered from Poland for £150. Genuine parts too. Sent a message via eBay and we sorted it out via email and got a PP invoice. On the mobile just now but will post a link when home if you're interested.
Service costs is also a pain I will be feeling soon. Not a lot of choice up in NE Scotland that I would trust or like thief stamp in my book. Unless anyone can advise otherwise.
Sonnyjim
'Their' not "thief", bloody iPhone won't let me change the word.
Sonnyjim
I just got 4 TPMS units off ebay for £125 delivered.
RS4 Avant - Misano Red
Including stems? That's a good deal.The_Coat wrote:I just got 4 TPMS units off ebay for £125 delivered.
Sonnyjim
I have just dealt with Northampton Audi today. They are happy for me to provide my own oil which will cut the cost of the service from £570 - £385. They wanted £180+ for oil! Crazy!
I'm pretty happy with that.
2007 Daytona Grey Audi B7 RS4
Yes the whole lot, I'll dig out the seller as he may have more. Was based in the UK also.Sonnyjim wrote:Including stems? That's a good deal.The_Coat wrote:I just got 4 TPMS units off ebay for £125 delivered.
Sonnyjim
Edit: http://pages.ebay.com/link/?nav=item.vi ... 1578439806
Mine went in to basingstoke recently for an oil leak which was covered under warranty but my contact told me their labour is £130 an hour so they can do better.
Thanks for the info guys. At £125 a set it might be worth just replacing the whole unit. May have a go at replacing the stems and giving the threads of the valve housings a bit of a clean up and see if it helps.
As for the stealers, I'll see if I can't play them off each other a bit.
Every little helps and all that...
Much cheaper and simpler is to have the TPMS disabled via Vagcom and use standard valves. These will be included in the tyre fitting.
- Surrey Sam
Audi offer a price match facility for servicing work. Worth having a read:Dan-RS4 wrote: As for the stealers, I'll see if I can't play them off each other a bit.
https://www.audi.co.uk/owners-area/serv ... match.html
Good shout Sam. I used the price match recently on a set of four Michelin Super Sport tyres. We're around £570 from memory.
I was happy with the service and spark plug charge at about £420 too.
You can replace the valve stem i.e. the bit with the thread on and the valve itself without needing to change the TPMS units. I had all 4 of mine done when I got new tyres a while ago, they were about £15 each fittedSilverfox42 wrote:
RS4 Cabriolet - Phantom Black with Exclusive interior
Marc1 where did you find the super sport's for £570? I paid £710 for mine and thought that was quite cheap.
Has anyone got a picture of the TPMS units? And how they're put together?
Cherub72, where did you go to get the valve stems replaced?
How old are the TPMS units you have in the wheels at the moment? If they are the originals they may not have much life left in them anyway, so maybe we'll worth replacing the whole lot.
Users browsing this forum: Google [Bot] and 1116 guests
