Timing chain
Re: Timing chain
I had my tensioners replaced when the engine was out having valves cleaned at 44k.
Just a precaution but only a couple of hundred quid and peace of mind.
Re: Timing chain
I'd agree - if you've got the engine out for what ever reason then this is the kind of preventative stuff you might as well do.
It's like the one way valve under the intake manifold - silly not to replace if you have that off for any reason.
- PetrolDave
Re: Timing chain
You're putting words in my "mouth" - I said mine rattles less, in fact it's so much less that IF there is any chain rattle it's inaudible above the other normal engine noises.BlingBling wrote:So yours does rattle but less than the S4 after 18mths. So how can you agree with TimDogg's catagorical "No" that there is no chain rattle?. Make your mind up.
I think you have made your mind up that there IS chain rattle and are looking for "evidence" to support your assumption. Evidence that I am not going to give you because I have no such evidence.
Re: Timing chain
I've had a good listen to mine and you can't hear the chain at all. Granted, might be as Dave says covered up by the other noises especially the "supercharger-but-obviously-not-cause-it-aint-there" whine.
- PetrolDave
Re: Timing chain
I wonder what the cause is of this (brilliantly described) whine?adsgreen wrote:especially the "supercharger-but-obviously-not-cause-it-aint-there" whine.
Re: Timing chain
I'd like to know as well! I've had mates ask me what the whine was and all I could make up was "er, yeah, that's the, um, drive train"PetrolDave wrote:I wonder what the cause is of this (brilliantly described) whine?adsgreen wrote:especially the "supercharger-but-obviously-not-cause-it-aint-there" whine.
- TonyHayers
- 5th Gear
Re: Timing chain
Isn't the whine just a characteristic of chains? what I assumed tbh.
06 Phantom Black Saloon:
^ GONE
^ GONE
- RossDagley
- Top Gear
Re: Timing chain
Just out of interest (appreciate this thread is now a few years old) but I've just had a quite of circa £1500 for timing chain / guides replacement - that's with the engine already out.pad125 wrote:I had my tensioners replaced when the engine was out having valves cleaned at 44k.
I'm not sure if I can justify it - even on a high mileage car I want to keep.
Previously:
Previously:
Re: Timing chain
If you are keeping the car it is going to have to get done at some point. £1500 is cheaper than a new engine.
I will be doing mine in a year or so it takes to cover the extra 25,000 miles.
Cheaper than some of the other work these cars need doing on a yearly basis!
Misano Red RS4 B7 Avant
- RossDagley
- Top Gear
Re: Timing chain
But where does this idea come from? Audi say the chain and tensioners are fit for the life of the vehicle. Has there been reported cases of failure? (In the rs4 not the s4).coffey555 wrote:If you are keeping the car it is going to have to get done at some point. £1500 is cheaper than a new engine.
Previously:
Previously:
- RossDagley
- Top Gear
Re: Timing chain
Also I got the sums wrong on the quote.
Timing chain and associated parts (tensioners etc) price was circa £2100 - not including the £2k to take the engine out and replace. It's a vast amount of money
Previously:
Previously:
Re: Timing chain
I've got a pretty good relationship with the service manager at my dealer and he worked it so he just charged me for the parts. The engine was out and in bits at the time though
- RossDagley
- Top Gear
Re: Timing chain
Parts alone are £1500 !pad125 wrote:I've got a pretty good relationship with the service manager at my dealer and he worked it so he just charged me for the parts. The engine was out and in bits at the time though
Previously:
Previously:
Re: Timing chain
..............going to check my invoice now.....
- RossDagley
- Top Gear
Re: Timing chain
any joy?pad125 wrote:..............going to check my invoice now.....
Previously:
Previously:
Users browsing this forum: Google Adsense [Bot] and 123 guests
