HELP.......TPMS problem
- willywonker RS4
Hi everyone
Hope someone can help with a problem I have with my B7 audi rs4, I drove the car yesterday for the first time in 2 weeks and the TPMS flashed up red with no Amber warning just a straight red, I stopped at a garage and filled the tyres with air, one was very low 26psi not 33 so I reset it using the RS steering wheel, cleared the warning and drove off, 2 miles later it flashed red AGAIN, checked the pressures but nothing wrong, It doesn't want to stay resetted.
Please help
Please help
bluenosewrx
Re: HELP.......TPMS problem
Sensor gone mate, prob need to replace it, AFAIK btys only last 4-5 yrs, prob best changing all 4, plenty threads on here if you search,
- willywonker RS4
How much are they a pop and won't it be easier just to have someone over right this and is it ok to drive with that on the dash or will it cause more problems
As long as you know the pressures are fine it won't cause any problems at all. You can turn the system off but not sure if you use VCDS or can select from the menu where you set pressures.
rs4 b7 daytona avant. Miltek resonated valved, Mrc stage 2
vw touran 2.0tdi, blue /black leather. family wagon!!.
repsol honda fireblade.
Zx12r b1 in black and gold. The colour to have!!
- willywonker RS4
Hirocket1 wrote:As long as you know the pressures are fine it won't cause any problems at all. You can turn the system off but not sure if you use vcds or can select from the menu where you set pressures.
I've tried resetting it on the display menu but it only last 2 miles then bleeps red again, I've heard u can take it to a garage with audi knowledge and if they have the software they can disable it which works out cheaper than replacing 4 sensors as I'm not sure which ones knackered
- RossDagley
- Top Gear
Anyone with VCDS can disable it for you - don't go pay a garage! You're welcome to pop over to me (MK443AP) if you can't find someone closer to help - I'll do it for you in under 1 minute.
Previously:
Previously:
- willywonker RS4
Hi Ross, what is VCDS and where abouts are u to Milton Keynes?
- RossDagley
- Top Gear
I'm about 20 miles from Milton Keynes - black cat roundabout on the a1. Directly down the a421 until you hit it
VCDS is Vagcom by another name - the software and hardware required to talk to all the cars ecu. Change settings, read codes etc
Previously:
Previously:
If you need new ones this guy should take £30 each if you put a snide offer in.
http://pages.ebay.com/link/?nav=item.vi ... 1449941807
RS4 Avant - Misano Red
- willywonker RS4
I know where that is, when can I pop over and how much do u want for the service m8RossDagley wrote:I'm about 20 miles from Milton Keynes - black cat roundabout on the a1. Directly down the a421 until you hit it
Vcds is vagcom by another name - the software and hardware required to talk to all the cars ecu. Change settings, read codes etc
- RossDagley
- Top Gear
I work from home so am in most days - just drop me a PM a day in advance with a rough time and we'll hook up
No charge don't be silly - bring a packet of biscuits if you want anything with your cup of tea
Previously:
Previously:
- willywonker RS4
How about Thursday if your free and between 9am and 10am, I can come straight from work as I work nights so won't take me that long to get to yoursRossDagley wrote:I work from home so am in most days - just drop me a PM a day in advance with a rough time and we'll hook up
- flying_tomatoes
Exactly this. This seems to be popping up on all the boards lately. I guess its just about that time.bluenosewrx wrote:Sensor gone mate, prob need to replace it, AFAIK btys only last 4-5 yrs, prob best changing all 4, plenty threads on here if you search,
2007 RS4 - Bagged and Blown. IG: @Flying_Tomatoes
Ive got the same issue, doing my nuts in. Can you tell which one it is on Vagcom or is it best to just replace each corner?
Anyone used these ?
http://www.ebay.co.uk/itm/261203447212? ... EBIDX%3AIT
http://www.ebay.co.uk/itm/301277497754? ... EBIDX%3AIT
Anyone used these ?
- RossDagley
- Top Gear
Vagcom wont tell you which sensor it is unfortunately. It's a very basic tpms system.
Previously:
Previously:
Users browsing this forum: Zyox and 161 guests
