Hello All, just a quick question, my car was recently serviced by Audi and they used Fuchs Titan GT1 (all that was listed on the receipt). I asked them not to do the Longlife service but they did anyway - my French is not so good.
I want to buy oil for top ups and wonder if I should continue to top up with the Longlife oil as follows:
Fuchs TITAN GT1 LONGLIFE III 5W-30 Premium Synthetic meeting VW504.00, VW507.00
Or if I can use the other version:
Fuchs TITAN GT1 PRO C-3 XTL 5W-30 Synthetic Engine Oil For the latest VW - BMW and Mercedes Vehicles.
What is the difference between the two and can/should they be mixed?
I prefer a more regular service interval with regular oil changes and will go back to this.
Thanks in advance for any advice.
Daniel
A Question About Fuchs Oil
manual_daniel
Now: 2007 Daytona RS4 Avant
Passed On: 2003 Mugello RS6 Sedan
Re: A Question About Fuchs Oil
Daniel,
I've use Fuchs TITAN GT1 PRO C-3 XTL 5W-30 Synthetic Engine Oil in my RS4 since I've had it. It's good oil. I've not used the Longlife alternative.
The C3 gets to temp quicker I've noticed but has a slightly lower running temp too. This is fully VW504 and VW507 approved
The difference I think one has added XTL and the long life doesn't. If I were you, and change oil regularly, I would certainly go for the XTL version.
http://www.opieoils.co.uk/p-980-fuchs-t ... icles.aspx
Good luck.
Good luck.
Gone but never forgotten:
manual_daniel
Thanks very much for the answer and the good information. Do you think that because I have the Longlife now I should top up with the same stuff, or switch to the XTL for top ups?neilparf wrote:Daniel,
Good luck.
Personally, I would try and stay with the same oil and - even though it's compliant...manual_daniel wrote:Thanks very much for the answer and the good information. Do you think that because I have the Longlife now I should top up with the same stuff, or switch to the XTL for top ups?neilparf wrote:Daniel,
Good luck.
manual_daniel
Thanks again, I'll buy the Longlife and switch to XTL at the next oil change. I definitely notice lower temps with the Fuchs compared to Castrol Edge.neilparf wrote:Personally, I would try and stay with the same oil and - even though it's compliant...manual_daniel wrote:Thanks very much for the answer and the good information. Do you think that because I have the Longlife now I should top up with the same stuff, or switch to the XTL for top ups?neilparf wrote:Daniel,
Good luck.
Me too - I barley hit 108-110 when pushing very hard...manual_daniel wrote:I definitely notice lower temps with the Fuchs compared to Castrol Edge.
For me 'progressive' driving is normally around 98-102...
Damn, already bought castrol edge for the next oil change :/
I've seen mine nudge 120 with almost continuous high revs and full throttle. Normal 'spirited driving' sees it to 100-110 normally.
Users browsing this forum: Google [Bot] and 213 guests
