Control arm torque
RS4_Ollie
Control arm torque
Post by RS4_Ollie » Wed Oct 08, 2014 4:34 pm
Hi,
Got my 034 control arm set through today and am going to fit ASAP.
Can anyone enlighten me on the torque values for the various bits especially the pinch bolts on the top of the upright as I don't want to be cracking the alu.
Cheers :beerchug:
HEKTOR
Trader (Expired)
Re: Control arm torque
Post by HEKTOR » Thu Oct 09, 2014 8:47 pm
Ollie these should be correct
Upper front; 50 Nm + 1/4 turn into mounting bracket
Upper rear; 50Nm + 1/4 turn into mounting bracket
Upper pinch bolt; 40 Nm (not TRE pinch bolt)
Lower front; 80 Nm + 1/4 turn into subframe
Lower rear; 90 Nm +1/4 turn into subframe
Lower control arms into steering knuckle; 100 Nm
Mounting bracket (shock tower assembly)
Upper bolts from inside the engine bay; 75 Nm
Lower nut and bolt into control arm; 90 Nm
Sway bar end link;
Lower connection to the sway bar; 100 Nm
Upper connection into the control arm; 40 Nm + 1/4 turn
Rear Sub Frame; Large Bolt 110 Nm + 1/4 turn small bolts; 23 Nm
RS4_Ollie
Post by RS4_Ollie » Mon Oct 13, 2014 8:23 am
that's great, thanks
:beerchug:
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot] and 134 guests
