Ceramic brakes
Ceramic brakes
There is a beautiful white edition RS4 2008 for sale in sweden, and i want to go and look at it. It has 100.000km on the meter - so im just wondering, when is it time for the brake change on the ones with ceramic brakes? Ive been told the price tag on changing the disks are about £4500? True, false?
Audi RS4 Avant
[2014]: blacked out wheels & grill: center res delete : flaps open
[2015]: brembo & yellowstuff : michelin pss : h&r spacers
[2016]: sachs performance clutch : decoked : led there be light : black window trim
[2017]: stertman stage 1 : black headlights & clear corner mod : gruppe m air intake : gutted resonators
- PetrolDave
Re: Ceramic breaks
Brakes are what stop your car, break is what your car does when your brakes don't work
In some countries I believe that Audi offer a 150,000km warranty on the ceramic discs.
Re: Ceramic breaks
From recent posts and having covered 100k kilometers they will be a liability IMO and I would allow £5k plus for a new set.
Re: Ceramic breaks
Hahaha sorry, my bad. I thought all the way something wasnt quite right.PetrolDave wrote:Brakes are what stop your car, break is what your car does when your brakes don't work
Thanks for the info you two!
Audi RS4 Avant
Re: Ceramic brakes
100km is how many miles??
If its just road use, they will be more than fine...it depends how much hard track use they have had...
Re: Ceramic brakes
62k miles
rs4 b7 daytona avant. Miltek resonated valved, Mrc stage 2
vw touran 2.0tdi, blue /black leather. family wagon!!.
repsol honda fireblade.
Zx12r b1 in black and gold. The colour to have!!
Re: Ceramic brakes
Audi reckon that the discs are good for 300,000km under normal driving, but as D_K says, this is likely to be a bit shorter if tracked.
8L S3 with stage 2 (gone)
B7 A4 DTM (gone)
B7 RS4 (Miltek Res Valved, 100 cell cats, Ceramics, Carbon cleaned) gone
C7 RS6 Panther, carbon pack,
B7 A4 DTM (gone)
Teutonic_Tamer
Re: Ceramic brakes
In the UK, the ceramic discs retail at about £2100 each. SGL Carbon, who make the discs for Audi (as well as for Porsche and Lambo) state the service life is 150,000 miles. As for wear - they don't wear in the conventional sense, they degrade and loose mass when overheated. So they should really be weighed to determine when they need replacing.
Sean - Independent Motor Vehicle Tech (ret'd)
'07 Audi B7 RS4 (with ceramic brakes) - WOW!
'06/7 VW Golf Mk5 GTI 2.0T FSI DSG 5dr
'03 Audi B6 S4 4.2 V8 6sp man (gone)
Re: Ceramic brakes
Apologies if this has been covered a million times but, is it a straight forward swap to standard discs on a car fitted with ceramic ones when they are ready for a change?
Re: Ceramic brakes
I think you will need to change callipers as well as the ceramics are a different diameter. Probably bits of coding to do as well to let the system know you have changed.cheese666 wrote:Apologies if this has been covered a million times but, is it a straight forward swap to standard discs on a car fitted with ceramic ones when they are ready for a change?
B7 A4 DTM (gone)
B7 A4 DTM (gone)
Teutonic_Tamer
Re: Ceramic brakes
Diferent discs, differnet pads, different calipers, different splash shields.cheese666 wrote:Apologies if this has been covered a million times but, is it a straight forward swap to standard discs on a car fitted with ceramic ones when they are ready for a change?
Audi do an official retro fit kit containing all the bits you need (except the splash shields), including a CD-ROM with a few pdf documents on there. Part number is 8E0 098 203. Make sure a sturdy seat is nearby when asking for the price thou!
- Surrey Sam
Re: Ceramic brakes
Teutonic_Tamer wrote:Diferent discs, differnet pads, different calipers, different splash shields.cheese666 wrote:Apologies if this has been covered a million times but, is it a straight forward swap to standard discs on a car fitted with ceramic ones when they are ready for a change?
TT - Is that not the Ceramic retrofit kit, I read the question as swapping back to the steel setup? From reading your historical posts I see that you're a stickler for correct information, so wouldn't want any duff information out there?
Users browsing this forum: Majestic-12 [Bot] and 247 guests
