tips needed for my B7 RS4
Spaceman_RS4
Re: tips needed for my B7 RS4
No they don't unfortunately wrong offset
Ordered b9 S4 Avant ibis white
Panther black 8V RS3
Misano Red B7 RS4 Saloon
The last 2 days I noticed that my RS4 holds back slightly when accelerating and changing gear. So lets say when in 2nd gear reving to 8000 revs, changing to 3rd gear and pressing full throttle again I notice it holds back 5000-6000revs. This doesn't happen every time but does worry me slightly.
The engine doesn't start immediately either when pressing the "start" bottom".
Could this be due to carbon build up?
Daytona Grey B8.5 & Guards Red 981 / Ex.Audi RS4 B7 Sedan, Daytona Grey.
- PetrolDave
Do you have to hold the start button down to make it start?rob-s wrote:The engine doesn't start immediately either when pressing the "start" bottom".
Could be clutch switch...
RS3 8P 2013 Phantom Black with Ally Pack and Black Optics Grille | LED Interior and number plate lights - GONE
RS4 B7 2006 Phantom Black with Titan alloys and mirrors - GONE
Vacuum leakrob-s wrote:The last 2 days I noticed that my RS4 holds back slightly when accelerating and changing gear. So lets say when in 2nd gear reving to 8000 revs, changing to 3rd gear and pressing full throttle again I notice it holds back 5000-6000revs. This doesn't happen every time but does worry me slightly.
turn your traction control off!.rob-s wrote:The last 2 days I noticed that my RS4 holds back slightly when accelerating and changing gear. So lets say when in 2nd gear reving to 8000 revs, changing to 3rd gear and pressing full throttle again I notice it holds back 5000-6000revs. This doesn't happen every time but does worry me slightly.
b7rs4 phantom black, titan pack.
Well..actually this comment is spot on! This morning I gave it a try (again) and noticed that the cause is winter tyres + wet road. The traction control reduces very shortly power due to wheel spin.turn your traction control off!.
I once red that its possible to deactivate the "check at start" via VCDS (ross-tech) but cannot find it back. As a result the car would't give "OK" when starting the engine.
Does anyone know where is can be deactivated?
- esp_mm-270
Not got rear grills on but a bit like mine? 5 post down......MikeFish wrote:Dec, I think he was talking about the mesh part of the front grill rather than the surround, and at the back he was talking about the bit under the bumper not the bit on top of it.
Rob, if you are along about the bumper strip at the top of he bumper I have had mine sprayed phantom black as it would have been on a black optic car, and YoungBen had his done in carbon. But I think you meant the bit under the back bumper didn't you?
http://forum.rs246.com/viewtopic.php?f= ... &start=135
Users browsing this forum: Bing [Bot] and 264 guests
