Haha - no supercharger yet!!sakimano wrote:Gavla wrote:Thanks - will try these again once it's been cleaned.
Unless you're running a small supercharger, those 7.0 times are pretty incredible. Care to explain the method for making the times? Are you going to post the video soon?
It works well to just have the on board stopwatch running wihle you film the DIS+tachometer+speedometer. That way you can pause the video right at 3k, look at the time on the DIS stopwatch, then do the same at 8k.
As I said however 7.0 is not far off what APR supercharged cars run.
I've dropboxed the videos below and as stated above I took the time from the iPhone video file(s) through my video editing suite (PowerDirector) - your welcome to try them - only think that the temperature was 10C so that might contribute to the above norm times - also floored at 2K so it hit the ground running
https://dl.dropboxusercontent.com/u/90487388/016.MOV
https://dl.dropboxusercontent.com/u/90487388/017.MOV
https://dl.dropboxusercontent.com/u/90487388/019.MOV
Quicktime viewer needed...
