Cruise control stopped working so likely issue is clutch switch I believe. Looks a DIY fix, one question is when you put the new switch in should the clutch be pressed in? Plus any other tips?
Cheers all!
Clutch switch
Re: Clutch switch
No. just quarter turn, take out old switch, swap over and reverse to fit.pablotommo wrote:Cruise control stopped working so likely issue is clutch switch I believe. Looks a DIY fix, one question is when you put the new switch in should the clutch be pressed in? Plus any other tips?
Cheers all!
pablotommo
Re: Clutch switch
Cool, presumably clutch switch above clutch and brake switch above brake?
- F@tBoyF@t
Re: Clutch switch
http://forum.rs246.com/viewtopic.php?f= ... CH#p544837
SEE ROY'S step-by-step process to change the clutch switch - really should be a sticky?
"57" RS4 Avus Avant
Re: Clutch switch
Must... Resist... Sarcastic... Answer....pablotommo wrote:Cool, presumably clutch switch above clutch and brake switch above brake?
pablotommo
Re: Clutch switch
Cool thanks for the link!!! :0)
- F@tBoyF@t
Re: Clutch switch
Cool.....adsgreen wrote:Must... Resist... Sarcastic... Answer....pablotommo wrote:Cool, presumably clutch switch above clutch and brake switch above brake?
"57" RS4 Avus Avant
Users browsing this forum: Google [Bot] and 145 guests
