Clutch switch
pablotommo
Clutch switch
Post by pablotommo » Wed Dec 19, 2012 4:59 pm
Cruise control stopped working so likely issue is clutch switch I believe. Looks a DIY fix, one question is when you put the new switch in should the clutch be pressed in? Plus any other tips?
Cheers all!
adsgreen
Re: Clutch switch
Post by adsgreen » Wed Dec 19, 2012 5:44 pm
pablotommo wrote:Cruise control stopped working so likely issue is clutch switch I believe. Looks a DIY fix, one question is when you put the new switch in should the clutch be pressed in? Plus any other tips?
Cheers all!
No. just quarter turn, take out old switch, swap over and reverse to fit.
pablotommo
Re: Clutch switch
Post by pablotommo » Wed Dec 19, 2012 6:22 pm
Cool, presumably clutch switch above clutch and brake switch above brake?
F@tBoyF@t
Re: Clutch switch
Post by F@tBoyF@t » Wed Dec 19, 2012 11:46 pm
http://forum.rs246.com/viewtopic.php?f= ... CH#p544837
SEE ROY'S step-by-step process to change the clutch switch - really should be a sticky?
:beerchug:
"57" RS4 Avus Avant
adsgreen
Re: Clutch switch
Post by adsgreen » Thu Dec 20, 2012 12:16 am
pablotommo wrote:Cool, presumably clutch switch above clutch and brake switch above brake?
Must... Resist... Sarcastic... Answer....
pablotommo
Re: Clutch switch
Post by pablotommo » Thu Dec 20, 2012 12:19 am
Cool thanks for the link!!! :0)
F@tBoyF@t
Re: Clutch switch
Post by F@tBoyF@t » Thu Dec 20, 2012 7:46 am
Cool.....
:biggrin3:
"57" RS4 Avus Avant
