RS4 - miltek exhaust and sports cat fitted - Lambada fault?
andi1
Post by andi1 » Wed Sep 07, 2011 12:05 am
Hi guys im new round here come from audi sport.net
Ive a b7 rs4 and recently had a miltek exhust and sports cats fitted (sounds amazing but) , ive replaced all the lambada sensors with new ones also but im still getting engine warning light faults and ive run VCDS and this is whats comimg up.
Is this common and does anyone know of a soloution? :beerchug:
Address 11: Engine II Labels: 079-910-560-BNS2.lbl
Part No SW: 8E1 910 560 HW: 8E1 907 560
Component: 4.2L V8/4V FSI ª0080
Revision: --H15--- Serial number: XXXXXXXXXXXXXX
Coding: 010C0003180F0160
Shop #: WSC 01286 386 08256
****1 Fault Found:
000080 - Oxygen (Lambda) Sensor B2 S1: Heating Circuit: Malfunction / Open Circuit
P0050 - 004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 0
Fault Frequency: 98
Mileage: 82028 km
Time Indication: 0
Freeze Frame:
RPM: 755 /min
Load: 20.4 %
Speed: 0.0 km/h
Temperature: 78.0°C
Temperature: 36.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.716 V
thanks guys
RS4pete
Re: RS4 - miltek exhaust and sports cat fitted - Lambada fau
Post by RS4pete » Wed Sep 07, 2011 12:23 am
Did you have a remap at the same time?
B7 RS4
Mi16'd 205 1.9 Gti
1999 Yamaha R6
White Transit :)
andi1
Post by andi1 » Wed Sep 07, 2011 12:41 am
Hi not at the same time no but i have had one done since by a local firm but the fault is still there,
do you think a remap would cure it? Should i have asked them to do something in particular i did mention it had the miltek
Whats worrying is thats its not saying the lambada is out of range its saying its P0050 - 004 - No Signal/Communication - MIL ON
Car smells like its running rich too
thanks
grizz
Post by grizz » Wed Sep 07, 2011 8:31 am
The lambda needs testing , I would say it's cooked ..
Unit 20
0151 3366888
andi1
Post by andi1 » Wed Sep 07, 2011 11:59 am
Hi ok whats the best way to test it out guys?
thanks
Doug_S2
Trader (Expired)
Post by Doug_S2 » Thu Sep 08, 2011 8:01 am
Heater circuit is not working which means the the sensor is damaged internally. 98 occurances means proabbly 98 starts - not an intermittant fault. It needs replaced.
http://www.MRCtuning.com
andi1
Post by andi1 » Thu Sep 08, 2011 6:42 pm
ok il tryt another sensor and see whats what
thanks again guys
Users browsing this forum: Bing [Bot], Google [Bot] and 128 guests
