Adaptive light error
AxiomX
Post by AxiomX » Wed Apr 07, 2010 7:19 pm
Hey All
I have just received an error on my adaptive light system, it started one day by the driver main dipped light not switching on and an bulb out warning, i switched off the car and restarted, driver main dipped light worked again but the adaptive system came up with an error.
Here is the error details:
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 E HW: 4F0 907 357 E
Component: AFS 1 H01 0010
Revision: 00000001 Serial number:
Coding: 0000019
Shop #: WSC 06335 000 00000
Part No: 8E0 941 329
Component: AFS-Modul links H03 0020
Component: AFS-Modul rechtsH03 0020
1 Fault Found:
02234 - Right Headlight Power Output Stage (J668)
014 - Defective - MIL ON
Freeze Frame:
Fault Status: 11101110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Have any of you had this error?
According to the VAG site, when i serached for the error:
02234 - Right Headlight Power Output Stage (J668): No Signal/Communication
Possible Causes
Wiring from/to Right Headlight Power Output Stage (J668) faulty
Possible Solutions
Check Wiring from/to Right Headlight Power Output Stage (J668)
Check Right Headlight Power Output Stage (J668)
I checked all wiring, all seems fine, i ven unplugged the main cable to power up the light and plugged back in then checked the system but still the error pops up.
PetrolDave
RE: Adaptive light error
Post by PetrolDave » Thu Apr 08, 2010 7:03 pm
The fault frequency is 1, so try clearing it and seeing if it re-occurs.
If it doesn't then it was a glitch.
If it does then it sounds like a problem with the ballast/ignitor assembly on the RHS.
AxiomX
Post by AxiomX » Fri Apr 09, 2010 7:22 am
Cool thx PetrolDave, i have tried to clear the error but keeps coming back.
I am goin to a dealer tomorro for an oil change so i will get them to check it out as well.
snocrash
Re: Adaptive light error
Post by snocrash » Mon Aug 22, 2011 3:20 pm
I'm struck almost exactly the same issue - Did you resolve the problem?
adsgreen
Post by adsgreen » Mon Aug 22, 2011 3:26 pm
my guess is the ballast has failed.
AxiomX
Post by AxiomX » Tue Aug 23, 2011 8:54 am
Hi Guys
Soz, i neva replied earlier, but yes, the ballest failed.
Thx for your help.
Users browsing this forum: Google [Bot] and 149 guests
