Alloy wheel valves
Mendy
Alloy wheel valves
Post by Mendy » Sun Aug 07, 2011 2:11 pm
Help
Just went to check the tyre pressures on my RS4 and the valve has corroded/sheared off I managed to get the cap on enough to stop the air but dont want to use the car as it is. are these Audi parts or stock tyre fitter bits I will have to go to a tyre place to have them fitted I guess but do I need to buy from Audi first
P_G
Re: Alloy wheel valves
Post by P_G » Sun Aug 07, 2011 4:56 pm
The valve is £12 from Audi or TPS. Had to be an RS4 specific valve as it is part of the TPMS set up.
northernpar
Post by northernpar » Mon Aug 08, 2011 12:42 am
The valves are manufactured by Beru (43mm I think). You can also pick them up on e-Bay however I found Audi to be cheaper than the e-Bay price plus there's the added bonus of knowing that the parts will be correct.
PhilT
RS246.com
Post by PhilT » Mon Aug 08, 2011 7:54 am
That shouldn't happen with the plastic valve caps. Metal on metal is a different story though and requires an ample dose of petroleum jelly to stop corrosion.
P_G
Post by P_G » Mon Aug 08, 2011 7:58 am
Unfortunately Phil it does. Cleaning agents and just general salt / crap corrode these as well as using the car's own tyre inflator, they are surprisingly soft. I always have plastic caps on mine and still probably replace them every second set of new tyres.
Mendy
Post by Mendy » Mon Aug 08, 2011 12:50 pm
Cheers Guys, got some new ones today from Audi £13 or so plus VAT will switch to plastic caps from now on!!
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 188 guests
