Richie Garcia here... My Headlight washer gets stuck after use ..... just wanted to ask if anyone had the same problem... The passenger side gets stuck in the extended position , I have done some research on some other audi forums usually it's caused by snow / dirt or misaligned bumpers that might have hit one of the high pressure hoses or spring mechanism .... As suggested by other forums I filled the tank with water and tried to reset by running water thru the system... Sadly it Still gets stuck on its fully extended position ;( I tried pushing it back manually.. it feels like something is stopping it when I put a little more force water spurts out from the nozzle as it slowly retracts back in... When I do the process again it gets goes out normally but gets stuck again before going back in....
Any thoughts?
richieg888
Re: Headlight washer gets stuck after use
I had exactly the same problem with an A6 I had. Unfortunately it was a knocked front bumper that had caused the unit to be very slightly 'bent' and I mean very slightly. I never had it fixed as some little maggots ripped both out one evening a few days later (why???). I changed the car the following week and never bothered to get new ones.
Unfortunately IIRC I was quoted around £110ish (I think) to get the bent one fixed.
____________________
C5 RS6 Avant
Gone
MRC'd B7 RS4
B6 3.0 A4
C5 A6
Pug 405 NZ Touring Car
Toyota Landcruiser
C5 RS6 Avant
Gone
MRC'd B7 RS4
B6 3.0 A4
C5 A6
Toyota Landcruiser
