Brakes
bentara
Brakes
Post by bentara » Sun Mar 06, 2011 8:02 pm
Hi,
Brakes on my 2007 avant (26k miles) are not that brilliant and have bit of vibration.
I was thinking of getting them skimmed considering the cost of new ones.
Any advice on this and what pads to use front and rear ?
Thanks.
P_G
Re: Brakes
Post by P_G » Sun Mar 06, 2011 8:21 pm
You'll need to work out if it front or rear first. Rears can be skimmed on hub, fronts unless the skimmer in question is good should be done off the car as they are floating. Replacement pads, either Ferrodo DS2500 or EBC Yellowstuffs, both produce a lot less brake dust than OEM Pagid's and the latter have wear sensors in the fronts like OEM wheras the Ferrodo's do not.
bentara
Re: Brakes
Post by bentara » Sun Mar 06, 2011 10:43 pm
Thanks,
I was going to take the 4 of them off and get them done that way.
If i did have to replace them where are the best deals to be had ?
P_G
Re: Brakes
Post by P_G » Mon Mar 07, 2011 8:44 am
Couple of traders on here who I am sure will be along shortly; I usually pick mine up off fleabay new or used.
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 382 guests
