Dension Gateway 100 in RS4
steverobb1973
Anyone have a Dension 100 Gateway in their RS4. I picked up the ausi today and to my delight there was one fitted.... however it only seems to display every song as "track xx" from numbers 01 to 99, no other info at all????
Is this normal? If so it's worse than bloody useless!
Anyone know?
Steve
Anyone know?
Steve
- PetrolDave
Re: Dension Gateway 100 in RS4
Yep, unfortunately that's normal.steverobb1973 wrote:it only seems to display every song as "track xx" from numbers 01 to 99, no other info at all????
The only way to get track info on the RNS-E screen is to connect the iPod to an Alpine KCE-425i (IIRC), and connect the video output from that to a multimedia interface (like a Kufatec IMA Plus) to the RNS-E.
If you get the IMA Plus you can control the iPod from the RNS-E controls.
You do need to have the VIM (video in motion) SW mode done, otherwise the screen will blank when you go faster than 5mph.
steverobb1973
- PetrolDave
You can only play MP3 files from an SD card, so you need to setup iTunes to convert to MP3.steverobb1973 wrote:How do those sd card slot things work? Can I download direct from itunes to an SD card????
You're also restricted to a total of 512 objects (files plus folders) on an MP3 card, and they must be SD not SDHC or SDXC cards.
"SD" cards up to 2GB are SD, 4GB can be SD or SDHC, 8GB and above are SDHC or even SDXC.
- PetrolDave
TBH even when using the Sat Nav I find myself ignoring the nice big colour screen and using the DIS summary Nav info
Here is a video highlighting the features of the Dension Gateway 100 GW16AC1 fitted to an RNS-E in a Gallardo.
http://www.youtube.com/watch?v=_8h3_FoPo_4
2013 Ibis White RS7¬
¦ParkingPackPlus¦Sunroof¦HUD¦AudiConnect¦HeatedRearSeats¦RearSideAirbags¦RedBrakeCalipers¦QuattroPuddelights¦SoftCloseDoors¦NightVision¦Dynamic Package¦CarbonPackage¦CarbonMirrors¦21" GlossBlack¦ACC¦Stop&Go¦PreSensePlus¦SideAssist¦LaneAssist¦B&O¦BlackOptics¦OEMBlackBadging¦Gyeon Q2 Duraflex¦
- PetrolDave
steverobb1973's original post was ambiguous:craigyb wrote:Never mentioned the RNS-E screen, only the DIS.
So I thought it worth clarifying that the Gateway 100 CAN provides a solution for the DIS, but not for the RNS-E.steverobb1973 wrote:Anyone have a Dension 100 Gateway in their RS4. I picked up the ausi today and to my delight there was one fitted.... however it only seems to display every song as "track xx" from numbers 01 to 99, no other info at all????
steverobb1973
Thanks Guys, a solution for the DIS would be a good start and a big improvement on what I currently have, which is no info on the DIS or RNS, even the ipod is disabled......
tbh it seems like an absolute POS....
Where can I get info on the Dension 100 Gateway CAN version? how much is it?
Also i think I am going to try the SD card option, do you get the track details up on screen throutgh that?? If so is there a way that you can convert itunes files directly to mp3, without having to reload the cd's and re-rip them?
Steve
Steve
- PetrolDave
http://www.safensound.co.uk/densiondens ... pb8pt50lq7steverobb1973 wrote:Where can I get info on the Dension 100 Gateway CAN version? how much is it?
£109.99
steverobb1973
Was in a friends new S3 at the weekend and their RNS module looks different to mine. Main difference is that iphone links seemlessly, with all folders/playlists searchable and all text is displayed on both the RNS screen and DIS.
Anyone know where I can get one of these systems, what is it called and will it fit in my B7?
Steve
Steve
Users browsing this forum: Majestic-12 [Bot] and 390 guests
