Hi Guys,
i have been trying to figure out what the following codes mean, can anyone help?
001169 - Secondary Air Injection System: Bank 1: Insufficent Flow
P0491 - 002 - Lower Limit Exceeded - Intermitted
006435 - Please Check DTC Memory of ECU Number 2
P1923 - 008 - Implausible Signal
005137 - Secondary Air Injection System; Bank 2; Insufficient Flow
P1411 - 002 - Lower Limit Exceeded - Intermittent
I have cleared the system before but the problem is i have flat spots which come and go, does anyone have any ideas?
Martin
Fault code help
RE: Fault code help
I'm on my phone so can't check the wiki, but from memory this sounds like the message if you do the exhaust mod and don't fully seal the vacum pipe. Have you done your flaps?!
2007 Daytona RS4 Avant
RE: Fault code help
the car has a system (pump and valves) that injects air into the exh manifold under certain conditions
sounds like the pump, unlikely both valves would fail (unless you have low vacuum and they just aren't operating?)
pg 31 of the RS4 V8 study guide has good info
RE: Fault code help
I knew I recognised it - here's my post from years ago
1 Fault Found:
005137 - Secondary Air Injection System; Bank 2: Insufficient Flow
As you can see, Sebastian came straight back with the de-flapped answer -
http://www.rs246.com/index.php?name=PNp ... ic&t=70472
Another reason to support Ross-Tech!
1 Fault Found:
dutchbarge
RE: Fault code help
My car at Audi now with 9 faults codes, one of which is the same as yours: 001169 - Secondary Air Injection System: Bank 1: Insufficent Flow
When i pick the car up nextweek i will ask for you
dutchbarge
Martin, got car back yesterday, and the work carried out, they found the heating probes faulty in the exhaust system, N/S and O/S exhaust pipes, they replaced themMgbruce wrote:dutchbarge, Dom81,
cheers for the reply, dutchbarge, i look forward to hearing from you once you get your car back.
Martin
Part no: A1K0 998 262 AA LAMBDA PR / A079 906 262 B OXYGEN SEN
They have also updated the SW and then reset the fault codes, they have also told me to bring the car in next week so they can plug it in again to check if any of the fault codes appear again.
Hope this helps you
Users browsing this forum: Google [Bot] and 1007 guests
