Broken rear spring replacement, some questions.
I've got a broken near side rear spring, lost of couple of inches from the lower end. This one is been replaced under warranty by Audi but I am wondering if I should change the far side one too ?
08/2007 RS4 with 33K miles. Normal SS.
How much would a spring cost, and where is the best place to get one ?
Is it something that my local (non audi) garage could do, or even DIY ?
What is the correct part number for this, and do I need to replace anything else at the same time ?
Matthew
Matthew
RE: Broken rear spring replacement, some questions.
You need a 'special' tool to repressurise the DRC system, not sure if anyone outside of Audi have this.
I'd be tempted to Strike a deal and get H&R springs fitted all round (assuming you haven't got SS+?) I know of at least one main dealer that would do this.
Honest John in the Telegraph has been banging on about problems with car springs for ages. Due to way the ends aren't finished off properly they corrode and eventually break usually with a little help from a speed bump.
Re: RE: Broken rear spring replacement, some questions.
Do you need to repressurise the DRC when just changing a rear spring ?pippyrips wrote:You need a 'special' tool to repressurise the DRC system, not sure if anyone outside of Audi have this.
Can't you "just" take the old sping out and put a new one in without touching the shock ?
I was using Jimbo's previous experience as a guide but the more I think about it i think he had a dodgy shock, not spring so am not sure either way!MattShaw wrote:Do you need to repressurise the DRC when just changing a rear spring ?pippyrips wrote:You need a 'special' tool to repressurise the DRC system, not sure if anyone outside of Audi have this.
- 'R'e'S'pect_4
the rears can be replaced without depressurizing the DRC
iirc you drop the rear diff carrier, actually loosen it and lower it
obviously the fronts require the hoses to be diconnected since the strut is inside the spring....or do they?
maybe you can diassemble everything with the hose connected?
compress the spring and remove the hat (strut bearing)
put the new one on compressed, reinstalled hat, and reassemble?
has anyone tried, might be too tight and a real pita, lol
Not sure, probably a pot hole that finally finished it off.sonny wrote:How the hell did the spring break?..pot hole??
Noticed a metallic rattle from that corner. Thought it was the tool kit to start with, but had the wheels off for cleaning and noticed a 2-3 inch piece of spring sat inside the rest of the spring.
Users browsing this forum: Google [Bot] and 241 guests
