Steering wheel badge renew.
mboy
Post by mboy » Fri Mar 05, 2010 10:07 am
Does anyone know if you can buy just the badge for the steering wheel and if so how is removed, do you just pop it out or does the wheel have to come to bits?
caldy
FBSW Badge
Post by caldy » Fri Mar 05, 2010 10:40 am
Dunno if you can buy a replacement but you do need to split the bottom halves of the wheel to remove it. The badge has 2 small stubs that poke thru holes with 2 sprung clips on them, then covered with sticky felt. If you prise out the badge, you'll more than likely snap the rods and the clips will be left on the inner portion of the fbsw.
RS4 B7 Phantom Black
klauster
RE: FBSW Badge
Post by klauster » Fri Mar 05, 2010 11:31 am
Mine was scuffed if you are talking about the RS4 badge which is within the silver flat bottom area of the steering wheel? If so, pretty sure it comes as part of the flat bottom plastic part of the steering wheel. The entire silver plastic part including badge can be purchased from Audi, fitment is pretty easy (i Managed it... after i'd had it carbon wrapped ofc :)) price was something like £50...
Virdee Autos
Trader (Expired)
RE: FBSW Badge
Post by Virdee Autos » Fri Mar 05, 2010 8:06 pm
Yep new badge is part of the lower trim
Appx. £45, but may have gone up with the Audi price rise.
It has 2 Torx screws from behind (can't remember the size), and then the 2 halfs clip away.
Virdee Autos ~ 07950-526592
Ricky
RE: FBSW Badge
Post by Ricky » Sat Mar 06, 2010 6:36 am
Definitely cant buy the badge on its own because I tried when the badge fell out of mine. If my memory serves me correctly it was around the £65 - £70 mark for the entire silver plastic flat bottom bit with badge.
Hope this helps !
Ricky !
MB2
Post by MB2 » Sat Mar 06, 2010 10:30 am
One on eBay here - not cheap but better than a new silver bit maybe ?
http://cgi.ebay.co.uk/Audi-RS4-Steering ... 35a71fb36b
wellzieRS4
Post by wellzieRS4 » Sat Mar 06, 2010 4:46 pm
MB2 wrote:One on eBay here - not cheap but better than a new silver bit maybe ?
I brought this its not the right one it must be for a older RS4 its got a curve to it and doesn't sit flush in the recess but it still looks ok
drcarrera
Post by drcarrera » Sat Mar 06, 2010 5:45 pm
Had mine replaced under warranty - seems quite a lot break at some point.
Chris
06 Daytona RS4 Avant (B7)
Ricky
Post by Ricky » Sat Mar 06, 2010 7:28 pm
Mine was actually done under warranty too so if you car still has warranty thats the way to go......
Current: 2014 Sepang Blue B8 RS4
Previous : B7 RS4
Previous : Subaru 22B UK
Previous : Subaru Sti Type UK
Previous : VW Golf GTD
klauster
Post by klauster » Sat Mar 06, 2010 9:29 pm
wear and tear id imagine for most cases....
caldy
Post by caldy » Sat Mar 06, 2010 10:42 pm
Part number 8E 0 498 685 Trims
softail
Post by softail » Mon Mar 08, 2010 10:03 pm
I have a steering wheel badge that came off my 2007 RS4 car. The black paint has rubbed off a bit around the S and 4, but a bit of carefull touching up would sort it. The badge will just push into the two small holes on the alloy surround. the reason I know this is because I prised it off before Audi changed the whole surround. you can have the badge for £5 plus the cost of recorded delivery. Let me know if you're interested.
klauster
Post by klauster » Mon Mar 08, 2010 11:53 pm
My advice is bit the bullet and get the part for the silver part of the steering wheel, fitment is piss :)
Ade74
Post by Ade74 » Sun Jul 11, 2010 12:05 pm
I must be missing something...how do you split the two halves to get them off? I've undone the 4 screws but can't prise to two elements apart...reluctant to add a bit of force!
cabb
STEERING WHEEL BADGE
Post by cabb » Thu Jul 15, 2010 8:22 pm
JUST HAD MINE FITTED AT GLASGOW AUDI WHILE I WAS GETTING SOME OTHER WEE BITS SORTED IT WAS £104.00 SUPPLIED AND FITTED ABOUT £50 FOR BADGE £45 LABOUR AND A WEE BIT OF VAT
